Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Not operating correctly Sometimes doesnt fill all the way Sometimes doesnt go through the cycles correctly Somtimes it doesnt spin out correctly clothes still wet What needs to be replaced
    Filmmaker:
    Uploaded 5 video answers.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 14 Answers
Model number would be helpful just so I know what type of Centennial washer we are talking about...
If it's what I think it is, Here is a diagnostic guide to get error codes that may help to figure out the problem:
Maytag Centennial Washer Diagnostic Guide
My guess is the tub sensor...
Posted on Jun 10, 2015
    Genius:
  • Maytag Master
  • 1,585 Answers
Check pump for blockage also pressour switch
Posted on Apr 26, 2015
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
My washer doesnt cycle correctly, is it the timers fault?
the fault is likely your water level switch, you will find it at the end of a 1/4 inch rubber tubing coming from the drum area, easy to find, replacing this switch should restore normal operations of your unit.
Apr 16, 2012 | Maytag Washing Machines
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Intermitant various washer problems
Intermittment cycling is usually caused by either a loose connection or a timer issue. If all wiring is plugged in tight than you should replace the timer.
Jan 10, 2009 | Washing Machines
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
433 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
