Question about Kitchen Ranges
What is the fonction of the switch on the left side on the entrance (side of gas stove)?
  • 932 Answers
Gaby,
Most of the time that switch controls your oven light coming on. If you have no light coming on you need to replace the light bulb. Make sure you get an "Appliance" bulb because they are designed to take high temps and cold temps. Hope this helps!
Posted on Apr 23, 2015
Received new Maytag Gas Range. I have propane. . After switching the brass aperture to the propane side, there is no fitting to connect to gas line 3/8" female to 1/2" male the 3/8" has an odd thread
The odd thread might be a left-hand thread; fuel gas connectors often are.
As well as switching the air bleeds to propane you need to ensure the right gas pressure is being delivered to your stove.
A local plumber's merchant or similar should be able to supply the fittings you need.
Feb 04, 2017 | Grilling
I need to find a manual for a 1959 Kenmore gas stove
I have a 1959 Kenmore gas stove with the original owner's manual. My stove is a 36" with griddle in the middle, a rotisserie, and a small electric oven on the left side. Very unique. Please contact me for further information. Mary
Sep 17, 2013 | Kitchen Ranges
Where is the serial number located on stove?
If it is labeled like the other VGIC stoves, the serial number is on the left hand side of the burner box (stovetop). Remove the left side surface burner grates, burner bowl and grate supports.
I hope this helps.
Jul 22, 2010 | Viking VGIC485-6G Gas Kitchen Range
Hello the bottom of my stove doesn t light i
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Hotpoint RGB745 Gas Kitchen Range
Right side stove top igniters dont fire off of right side knobs+
clean the pilot jets out sonds as if they are clogged. if the right side is only being lit once the left side is on then you better not run the right until you do get it fixed as more than likely whats happening is the enough gas is traveling through the chamber to be ignited by the left sides flame and that can be dangerous, however your stove uses an electronic lighter all you need to do is clean the contact points so that they will spark cleanly if it still won't light you need a repairman.
Dec 07, 2009 | Ovens
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
Nov 27, 2009 | Stoves Premier 900GRa Gas Double Oven
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
Problems with Brown Stove Works TM110-3 Gas Kitchen Range
http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
there you go, the complete manual to operate your stove. look on page 16 to read about the pilot in the oven and how to proceed.
May 20, 2009 | Brown Stove Works TM110-3 Gas Kitchen...
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
I need advice asap about lexmark1185
My lexmark x1185 should be trying to print the envelope on the very right hand side of the entrance. However, when I lay the envelope on the right hand side of the entrance it will not print. The printer is typing on the left hand side of the entrance (the left hand side of a regular size paper). I cannot find how to change this problem. Please help
Jan 22, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
