Question about Coffee Makers & Espresso Machines
I've just had my Nespresso maestria delivered to my house today,but the steam wand not working ,no steam coming out whatsoever.
First thing I did which was filled the tank,and let the water run thru machine,basically like have it made a coffee without a coffee capsule,which worked normal. Then I switched on the Steam logo,but there's no steam coming out ,instead there's a humming sound "kuh~Kuh~"almost like there's air or sth in it. I took of the tip of the wand ,and cleaned it,then switched the maestria back on again,tried it, again nothing comes out. Any idea how to fix it ,thanks!
  • 25 Answers
SOURCE: steam wand
As the espresso is being made, you can steam the milk by opening the valve that goes to the wand. (sometimes there is a "switch")
To steam milk:
-Fill pitcher (or whichever container you want) with milk e**ugh for about 2/3 of your cup. A thermometer would be helpful.
-Place pitcher under the wand and lift it so that only 1/2 inch is under the surface of the milk.
-Open the steam valve. The milk will expand as it heats. Lower the pitcher to maintain the 1/2 inch depth. You should hear a "shushing" sound and have ** splattering.
-When milk is about 150 F (or preferred temp), close the steam valve and wipe the wand with a damp towel or else themilk will cake on the wand.
Good Luck
Posted on Mar 10, 2008
  • 5 Answers
SOURCE: Steam wand shooting water instead of steam
you should confirm right operation reference to instruction book,
perhaps need descaling for your machine.
Posted on May 26, 2008
SOURCE: steam wand not working
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Posted on Oct 08, 2008
  • 8596 Answers
SOURCE: can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Posted on Feb 26, 2009
  • 80 Answers
SOURCE: descaled machine, clean solenoid valve. now steam is coming
try replaced gasket in high pressure valve.
Posted on Aug 27, 2009
Testimonial: "this person is soooo helpful. It has been amazing to learn."
Where can I buy the gran maestria water tank?
I cannot find one but you can try calling 866-212-9040 to see if they can help you.
Jun 22, 2014 | Coffee Makers & Espresso Machines
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
Dec 20, 2012 | Nespresso Maestria Rosso
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Dec 28, 2008 | Nespresso D300 Espresso Machine
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Just says 'fill water'
this has happened to me. try opening the steam wand (but without the steam function turned on) to force hot water out. that usually gets it going for me.
Sep 16, 2007 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
83 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
