Question about GE Refrigerators
GE Refrigerator side is warmer temperature towards the front and much colder at the back. 10 degrees difference. (Some foods get frozen toward the back).
We checked out the thermometer.
    Top Expert:
  • GE Master
  • 10,875 Answers
Bad door gasket or openned too often
Posted on Apr 23, 2015
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
GE PROFILE PSW26SGRB SS
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature in the freezer! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Oct 12, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I dont understand temp dial on LG 232SBF Frost free fridge freezer
Hello there and welcome to fixya
this is actually a simple dial
this is what they mean
C= COLDER THIS IS THE SETTING IF YOU WANT TO LOWER THE TEMPERATURE FROM LETS SAY 38 DEGREES TO 35 DEGREES THEN YOU WOULD TURN THE DIAL A LITTLE BIT TOWARDS THE C
N= NORMAL RANGE THIS IS WHERE IT SHOULD BE SET AT AFTER IT IS AT THE TEMPS ARE ALLOWED TO STABILIZE
W=WARMER MEANING IF THE REFRIGERATOR IS TOO COLD MOVE IT TOWARDS THE W A FEW NOTCHES THIS WILL INCREASE THE TEMP MAKING IT A LITTLE BIT WARMER INSIDE OF THE REFRIGERATOR
OK? HOPE THIS HELPS PLEASE IF THIS HELPS GIVE MEA GOOD RATING I NEED ALL THE HELP I CAN GET
BEST REGARDS MIKE
Dec 21, 2011 | Radio Communications
Frig is getting colder and colder (below 25 degrees!)
Yor model if the model RS265LABP is very complex. It is very possible that the senser that feels the temperature in the fresh food section is defective. If you would like the manual to put the refrigerator into self diagnostics let me know. The diagnostics test for your model is done at the control panel and will tell you the problem. It will tell you the senser that is not working properly. But an easy fix for most people the test is simple but to go and repair the problem the answer is no easy fix. Sorry for the answer, Sea Breeze
Jul 22, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice crystal build up
Sounds like the cold air regulator needs adjusting or is blocked. There should be a lever somewhere near the inside top of the refrigerator whcih slides back and forth -- it should be labeled which direction to move it to make the non-frozen compartment colder or warmer.
Also check for frost buildup in the freezer -- if there is buildup, totally defrost -- there may be ice on the regulator which opens and closes based on temperature.
Apr 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can't get freezer to cool below 10deg F
For Olson- most combination units have a diverter that allows you to balance the flow of frigid air between the fridge and freezer. It may be located in the rear of your unit since the main cold air flow is done there.
Rockitman - not sure which temperature scale you are using - Olson specified 'F' and normal ranges for the refrigerator would be +35 to +45 degrees and freezer temps are recommended as -5 to 0 F. +10 degrees F wouldn't ensure that food would be very well preserved. Indeed, foods with any amount of salt in them may age at +10.
Feb 09, 2009 | KitchenAid KSSS36QK Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
