Question about Maytag Centennial MTW5800TW Top Load Washer
Machine does not go through the cycles correctly
Rinse cycle only fills halfway
alot of newer machines do that. water saving feature
Dec 04, 2015 | Roper Washing Machines
How to use the clean machine cycle correctly
in all of my many years we have never had a clean cycle on any machine so I would guess this is a big waste of your time and money
Oct 22, 2015 | Washing Machines
I accidentally set cycle to Self Clean instead of Spin & Drain and pushed Start button. Trying to reset to correct cycle. Have just moved and don't have manual on hand.
Most machines will reset if you press the stop button or otherwise end the cycle. If all else fails, un-plug the machine, wait a few minutes and plug it in. Otherwise, just let the Self Clean cycle finish.
Nov 14, 2014 | Washing Machines
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "defrost" is the harvest cycle correct?
Ice makers defrost is the harvest cycle. The purpose of a defrost cycle is to clear any ice build up, right?
Jul 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Oct 25, 2009 | Washing Machines
Washing machine, clothes come out very wet, as an incomplete spin cycle. I think the brake is out.
You can tell if the brake is out when you open the machine lid while it is in spin cycle,,, if it does not stop spinning quickly, then the brake is not working. but if it stops fast,, the brake is operating correctly.
I'm more apt to think this is a direct drive machine.
If you stand there and watch and listen,,, it should go from the aggitate cycle into the drain water cycle without any spin,,,this will last about 1 minute. Then it should kick into spin cycle once the tub is empty.
These machines are prone to wear after time that causes it to "shift" incorrectly,,, thus spinning when it should be only draining (kinda skipping the drain cycle of sorts)
You can visually check this by opening the door after the drain cycle starts to see if the tub is actually spinning inside. if it is,,, then the transmission is damaged and repair can become expensive.
I have taken the transmission out of an old machine and swaped to repair (if you have another good transmission that is)
You may want to look at the plastic and rubber coupling between the motor and transmission to insure it is in good shape if you find the transmission is shifting correctly as explained.
Oct 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Washing machine will not cycle
I have a Whirlpool Ultimate Care II. My washing machine would not cycle once it filled with water. I purchased a lid switch from partselect.com. The installation took five minutes. This corrected the problem. I hope this helps.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch wash front loader
code 00 means machine did not spin
check load for out of balance
redistribute load and restart
good luck
Aug 27, 2008 | Washing Machines
Maytag Centennial MTW5800TW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
