Question about Garden
I am looking for the part which attaches to the spindle. The part goes around and pushed the seed out of the hopper.
My hopper wont dispesence on my bunn IMIX-5 Tim Hortons
take the hopper out and press the button. if the spindle in the back doesn't move, the gear motor is siezed and needs to be removed, cleaned, lubed, and rebuilt. if the spindle moves, empty the hopper and reposition the auger so that it sits in the connector in the back, refill and test
Aug 07, 2014 | Bunn iMIX-5S BLK Powdered Beverage...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
How do I replace Gateway dx4831 fan?
The plastic snoot is probably just clipped on to the fan casing which is usually screwed to the heat sink. You could probably just remove the snoot
which will allow you to see what you need to do to remove the fan. The fan can normally be cleaned and a light grease applied to the spindle.
All you have to do is remove the fan, look underneath the fan and there should be a round label with things like the voltage, current, and make of the fan etc. Remove the label and if there is one, a little rubber bung, you will see the end of the spindle. There should be a small split washer around the spindle, it sits in a little grove on the spindle to hold it in to the fan motor. It can be removed with a small blade screwdriver. Just look for the split and carefully lift one end over the end of the spindle. Keep the washer for later. Then push the spindle out using a something like a cotton bud stem with the cotton cut off the end. It will try to go back in as it has a circular magnet inside the the fan around the outside of the spindle and is attracted to the metal part of the motor with the coils on. Clean the spindle and the hole it fits in then apply a thin grease or something like silicon oil or sewing machine oil. Push the fan spindle back in, put the split washer back and make sure it sits in the groove of the spindle by gently pushing on the end to ensure it does not slide out again. Put the rubber bung back(if there is one), clean any oil / grease from where the label sits and stick the label back on, they don't always stick once they have been removed but it can be replaced with a piece of adhesive tape.
May 11, 2012 | Computers & Internet
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a 200 buck regal and something is broken that goes to my drivers side front tire and I'm not sure what it is I don't know much about cars
Without a super awesome description of where the other end goes or a picture, it is going to be real hard to help you.
Mar 30, 2010 | 2000 Buick Regal
Im having trouble put in a ball joint in my 2000 taurus can anyon
The ball joint has pressure on it from the strut,it may be loose in the spindle,and you dont realise this.It takes a large bar,and two people to push it down far enough to remove it from the spindle.If you are sure it has not turned loose of the spindle,the take a big hammer and hit the spindle real hard multiple times near the ball joint,all around the spindle.Do not hit the ball joint itself.just where the ball joint stud goes threw the spindle,not the ball joint stud(don`t hit the stud)This will jar it free,but you will have to use a large pry bar and push down on the spindle control arm.
Sep 23, 2009 | 2000 Ford Taurus
Toner cartridge not loading
Cheat the front door interlock and watch the toner bottle to see if it is turning. If not, could be a bad toner drive motor/drive assembly. Otherwise, remove and disassemble the toner hopper and clean it up. Make sure the four clear 'scooper' tabs are attached on the back of the receptacle that fits around the top of the toner bottle. Otherwise, just purchase a new toner hopper, they are cheap.
Sep 15, 2009 | Ricoh Aficio MP 2000 Black and White...
Need instructions & diagram for belt replacement
its simple, the belt goes around the platter and the motor spindle, thats it!
Jun 05, 2009 | Audio Players & Recorders
Help
there is a small tube on the left side where the water comes out. Push a q-tip up there and wiggle it around. When I did it some glop came out and it works again. I have to do this about once a month.
Apr 24, 2008 | Danby DDR586R Dehumidifier
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
