Question about Beko Refrigerators
Why is my Beko Gnev 220s fridge freezer displaying error code 9 on the freezer part?
SOURCE: I own a Beko AP930
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Posted on Jul 31, 2008
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
SOURCE: LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Posted on Dec 09, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SOURCE: fault e8 displayed on beko
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Posted on Feb 22, 2009
I have a BEKO MODEL GN162320X the temperature display shows 0 in the freezer section and 33 in the fridge section can I reset the display
If you wish to get some details about refrigerator troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator..." http://electro-medical.blogspot.com/
Jan 22, 2017 | Beko Refrigerators
Tip
BEKO FRIDGE FREEZER SAFETY RECALL INFORMATION
I'm pasting this response on all queries regarding the recently announced issue with BEKO fridge freezers and the risk of fire from their defrost mechanisms, but I have placed it here in hints and tips too, in the hope it will be of use to any concerned BEKO Fridge owners:
According toseveral sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what Ican ascertain, the fridges affected were manufactured between January 2000 andOctober 2006 (So, after shipping and sitting around in shops, you can probablyextend that margin to machines SOLD between 2000 and 2008)
If you go tothe BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
I have tosay. Regardless of dates and matching serialnumbers, if I had an affected model,I would be checking with BEKO anyway!!
(And by theway I DO have a BEKO fridge freezer and I will be checking it out when I gethome!!)
on Jul 05, 2011 | Refrigerators
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Our fridge/freezer FN240-FG940 was purchased in 20002001. Is it subject to the currently identified overheating problems please?
This article refers to BEKO Fridge Freezers:
According to the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006
If you go to the BEKO website, there is a link to check your serial number:
But I have to say, matching serial number or not, if I had an affected model, I would be checking with BEKO anyway!!
Jul 05, 2011 | Beko Refrigerators
Fridge not Woking but freezer is what is possible causesBeko fridge freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Beko CDA670F (9 cu. ft.) Bottom Freezer...
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
Top Beko Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
