Question about Car Audio & Video
The radio system indicates "insert appropriate disc". Where can I get the disc?
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
Error Oxc00000e9 when i turn on aspire 5741, no external devices plugged in.
try this below
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
Feb 14, 2011 | Acer Aspire 5050-3371 Notebook
What to do if bootmanager fails?
hi frenofurs05,
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
7. Click the operating system that you want to repair, and then click Next.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
Jan 03, 2011 | Toshiba Satellite L500 Series Notebook
0xc00000e9
Hello.
This error can refer to hardware or software, depending on various circumstances.
Most likely, you have damaged system files.
You didn't indicate, but figuring that you have Vista, run System Recovery:
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
Hope this helps.
Jun 17, 2010 | Acer Aspire 5050-3371 Notebook
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
May 15, 2009 | Compaq Armada E500 Notebook
Avic drv50
Do you have the right navi disc. Because once you upgrade to newer version then when you put in an older version it will tell you to insert the appropriate disc. You need to downgrade it if you want to go back to older versions. Let me know if you need help on how to downgrade. Goodluck.
Oct 18, 2008 | Pioneer AVIC-N2 Car DVD Player
AVIC-N3
Hi check your navigation disc for dust, dirt, damage.
if disc is good, you might like to try running a dvd cleaner in the unit, the avic has a fan that sucks in dust from the car, and this coates the cd lens.
we can service the unit for £45.00 plus return postage @ £10.00 (uk mainland)
www.blueice-electronics.co.uk
Regards
Mark
Oct 01, 2008 | Pioneer AVIC-N3 GPS Receiver
Carrozzeria avic drv 250 problem
check out bootdisc.ru
I have the drv-250 and download the disk from here....works perfectly now
Jun 21, 2008 | Pioneer AVIC-N2 Car DVD Player
No read on all DVDs inserted
simple, lens have dirt or oil residue so just pop down to your nearest **** smith or radio shack & purchase appropriate cleaner.. test it when you get home & sure enough lens will be able to properly read discs again!!
May 20, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
