Question about Frigidaire Kitchen Ranges
After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Posted on Apr 29, 2015
bestdarngood
  • 3037 Answers
SOURCE: F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Posted on Mar 22, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
  • 360 Answers
SOURCE: F7 code and beeping
in version 1 of your model, F7 requires the replacement of the EDC (electronic door control)
in later versions F7 requires the replacement of the EOC (electronic oven control)
Posted on Feb 01, 2009
SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: I have a Tappan gas stove. Don't know how old the
Takes about 15 minutes to fix. You will need a philips head screwdriver, pair of scissors and a butter knife. What you're going to do is cut the wire to the beeper. Your clock will still function.
Start by removing the glass faceplate that encloses your clock. By removing the 2 screws on either side of the metal housing, you can remove the faceplate (you'll have to remove the clock's pushbuttons, but that isn't hard, either. I used some spring-loaded pliers to get a good purchase, then pulled straight back. Oh yeah. You need pliers, too. Don't worry, you won't break the buttons; they'll snap out and push back in, later). Use the butter-knife to carefully work the glass out of the metal frame. The actual clock is secured by a couple more screws, which are easily removed, once you've removed the abovementioned faceplate.
[The clock, btw, is made by Fridgidaire (part # AP2125434 ), in case you want to replace it. Costs more than $130(!)]
If you haven't already unplugged the stove, now is a good time. Do not touch the two metal connectors of the two most prominent wires on the back of the clock, when the unit is plugged in! Yes, it's the voice of experience, talking...
You will notice, when you're looking at the back of the clock unit, a small metal disc, enclosed in plastic. If you plug in the stove, and listen, you should hear the beeping coming from this area. There is a medium-sized hole in the middle of the plastic housing, allowing access to the metal disc. There are two very small wires, red and black, leading into the housing and attached to the disc in two places. One wire is attached to essentially the center part of the disc. The other wire (in my case, the black wire) is attached rather toward the outer edge of the metal disc. The outer edge is even a slightly different color, so you can identify the two parts. In my case, the sound was emitting from the outer edge, as opposed to the center portion of the disc. If you press a Q-tip against the center portion of the disc (thru the hole in the plastic housing), and the beeping continues, unchanged, the sound is probably coming from the outer edge. You can check by bending the Q-tip, and working the tip over to the edge of the metal disc--by applying pressure, you should hear the sound change, slightly.
Unplug the unit, and cut the wire that corresponds to the part of the disc the sound is coming from--that should solve the problem!
Posted on Nov 16, 2009
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
F11 error how to fix it?
F11 code is to indicate a shorted key on the touchpad, which explains your symptom...Replace the electronic oven control.
What is your model #? Help Me Find My Model Number RepairClinic com
Jul 24, 2016 | Frigidaire Kitchen Ranges
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
The electric stove I have is beeping f11 how do I stop it from beeping
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
Feb 25, 2015 | Frigidaire Kitchen Ranges
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
Beeping F11 error on Frigidaire stove. We have to stut off from the breaker to stove beeping
Jul 26, 2008 | Kitchen Ranges
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
907 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
