Question about Toshiba Televison & Video
Why won't my Toshiba 40RV525U turn on?
Standby light turns green when the power button is pressed
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 23, 2015
    Top Expert:
  • Toshiba Master
  • 45,018 Answers
Could be an open fuse or power supply failure
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
I have a toshiba 42RV530U and it won't turn on, no yellow or green light. what can be wrong. There is power going inn.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_5_2012_5_14_18_pm.jpg
May 05, 2012 | Toshiba 40RV525U 40 in. LCD TV
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Hi, I own a Toshiba 40rv525u lcd television set for 3 years. Suddenly, it turns on and off intermittently and I cannot solve the issue. I have already purchased and installed a new/used main board part...
Good day sir!!!
I want to know first if your TV have blinking lights red or green after the TV turns off?..if so,please count the blinking light to diagnose where the fault comes from..Or try to disconnect all connections of your TV such as DVD etc..then try again..
If the power supply and main board are both new..the possible problems are overheat or overload so please try the suggestions above..If not work please let me know if you have multimeter or if you know how to used it because we will proceed to voltage data..
Thank you for purchasing my service..
Have a nice day!!!
Jan 07, 2012 | Toshiba 40RV525U 40 in. LCD TV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Green light flashes on and off but wont turn on
That sounds like its not getting any power - enough to start up and then turn off.
Thought 1 is that the control panel power button is busted - the actual piezo switch.
Thought 2 is that there is a short in the unit such that power comes in, turns on the light, but then overloads the board and the thing shuts down.
May 16, 2010 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40RV525U green power light comes on but TV does not
toshiba often utilizes the green lamp for off, and the red lamp for on.
hope this helps!
Dec 07, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
