Question about Coby Televison & Video
I requiere to repair my COBY LED VD 1996 19 LED TV , the audio is lowed completely after few seconds of being turned on the TV..so that I need de service manual or schematics to check it out
    Top Expert:
  • Coby Master
  • 74,198 Answers
Check and replace damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 23, 2015
LG 55LS4500, after turning on the TV the picture goes out after a while but the sound stays on. Wait a few seconds and turn it back on and the picture will come on again but after a while goes out.
BUENAS SERIA BUENO Q REVISARA EL CIRCUITO DE ILUMINACI?N DELA PANTALLA DE TU TV EMPIEZA POR AH? PARECE SER UN PROBLEMA DE SOBRECALENTAMIENTO SI TU TV ES PLASMA YO TU IRIA A POR LOS IC QUE ALIMENTAN LA PANTALLA DE NO SER ASI POR Q EL TV ES DE LED O LCD REVISARIA LAN LAMPARAS Y EL INVERTER EN ESE ORDEN ESPERO Q DES MAS DETALLES PARA AYUDARTE MAS SUERTE
Dec 11, 2016 | LG 55LS4500 55 in. TV
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
How can i connect lg sound bar to my coby flat screen tv
You need to find an audio out connector.Either it is a digital output or a RCA connector.You also can take audio out from cable box.
Oct 13, 2014 | Coby 50" 1080p LED TV
Coby TFTV3229 won't stay on
Although it is not possible to be certain without on-hand inspection, a 5-second or less shutdown usually indicates a SAFETY system is turning the unit off - or that an essential voltage source or control circuit inside the unit is either out of range or has failed. Unless you're an electronics tech or have similar training, this is one of those times when repairs are best left to the pros.
Mar 11, 2014 | Coby TFTV3229 High Definition TV, 32"...
I need the TV remote code for a coby tv
Here are the codes for your Coby TV: 500, 503, or 00.
I have provided instructions on how you can program the remote to your TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network 721 DVR Remote Control
The Coby flat screen TV Serial number 0092152-0003048. Picture showing but no Audio. Sometime while the TV showing the audio will go off. i have to knock the back of the TV with my hand sometime then...
First off, unless you are an electrician or a television repairman that's familiar with very high voltage, It's not recommended that you do anything. It's best to call a repairman to repair. Even with the t.v. unplugged, It still holds a deadly voltage in it.
Jun 02, 2017 | Coby TF-TV3217 32 in. LCD TV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
My RCA l46wd22 46" lcd tv gets a picture but no sound thru speakers or thru headphone jack or audio out component. When i first turn on tv, the tv will have some sound that is very low but then goes away...
You will need to replace the main system control board to restore normal operation. The audio circuits are part of the main board and the only way to ensure complete repair is to replace this board
Jan 30, 2010 | Televison & Video
No Video or Audio
The lights are error codes. It means the system is nackered and needs repairing. Nothing you can do, it needs opening up and board testing
Dec 25, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV does not turn on
You have a short in your unit somewhere or a high voltage problem. The most common problem would be a high voltage failure. If you are not familiar with televisions and their safety this is best left to a repair shop. There is not much in a TV that consumers, unfamiliar with the system, can check. The problem should not cost too much to fix. Check for a shop which has a free estimate or low estimate which will be subtracted from the cost of the repair if you choose to have the unit repaired there. Good luck.
Jul 12, 2006 | Panasonic CT-27HL14 27" TV
Televison & Video Logo
56 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
