Question about Sewing Machines
What foot is the blind hemmer foot - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
Look in the operation manual, it should show you a picture of the foot
Posted on Jun 16, 2015
  • 749 Answers
SOURCE: Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Posted on Nov 17, 2007
  • 28 Answers
SOURCE: Blind hemmer
First get a new quality needle of the right size for your machine use a good quality hemming thread and check your tensions. If this fails to fix the problem you will probably have to have the timing checked.
Posted on Jun 07, 2008
SOURCE: Instruction manual for the tac sew t500 blind hemmer
I was looking for a manual for my T500 as well and stumbled across this site:
http://www.allbrands.com/images2/common/MSK-588_Instructions.pdf
It is for the reliable brand but they are almost identical and it is better than nothing!
Posted on Feb 17, 2009
SOURCE: tacsew t175-2 blind hemmer
I purchased mine from the Tacony Corporation. They also distribute/make babylock machines. Make sure you ask for the english version. There is really not much to it. They xeroxed and sent it to me. Google for their URL.
Posted on Aug 12, 2009
shastalaker7
  • 1515 Answers
SOURCE: babylock Blind Hemmer Model BL101
This sounds as though you are loosing the bearings in the spinning motor, as if it is hard to turn in manual, very tight, the motor bearings are going out, or are about out. You will need to take it to a repair shop for an estimate. If the bearings are of the oilable type, this may take care of the problem. Find the motor and see if it has oil cups on it. Use a 20 weight oil you can get at any hardware store to do this.
Shastalaker7
Posted on Feb 18, 2011
How I use blind hemmer stich fot
Google
"How to use a blind hemmer stitch foot"
and watch the YouTube videos...
Oct 04, 2014 | Sewing Machines
Blind hemmer is "frozen" won't move at all. What can I do?
on a normal sewing machine this usually means the threads are all snagged up in a knot in the bobbin case. Snip your threads, wriggle the fabric out, remove all snagged threads and rethread the machine. I don't know if this will work with your blind hemmer.
Apr 25, 2013 | Sewing Machines
How do I do the skinny narrow hem stitch
Blind hem or straight stitch with 1/8" or 1/4" hemmer foot. Fabric inserted into right-hand "tunnel". Always do a regular backstitch, forward stitch before inserting your fabric in. Makes it easier! Happy sewing. Suggestion: make miniature copy of your manual and you can always have it handy for reference. Jimmy
Apr 03, 2012 | Sewing Machines
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Nov 24, 2008 | Tacsew T500
Blind hemmer
Jun 06, 2008 | Sewing Machines
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
