Question about Panasonic KX-TG6841B DECT 6.0 Cordless Phone
Is there a call forward feature where i can transfer calls to the appropiate person?
Have a panasonic KX-TG6500 phone. I would like to know how to use call forwarding feature
Call forwarding isn't a "feature" on a telephone. You have call transfer to another handset, probably described in your manual, or Central Office call forwarding, the standard CF that works without the TG6500. You set that by following the CF instructions provided by your dial tone provider, usually a sequence that starts with 72#.
Carl
Sep 30, 2010 | Panasonic KX-TG6500 Cordless Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
How do I automatically transfer a call placed to 1 extension to ring at another extension? a co-worker was recently laid off and we need her calls to go to someone else
You can call forward the calls to the new extension by pressing feature 4 and the extension to forward the calls to on the laid off persons telephone.
Mar 26, 2010 | NorStar T7316E Corded Phone
How can i transfer calls from my Toshiba DKT2010-SD to another phone
To transfer calls, while on call press Conf/Trn and dial extension number. To Call forward your call to another extension there are three codes depending on what type of forwarding #601 - #604. Your guides and manuals are here
http://guides.idacomusa.com/
Jul 13, 2009 | Toshiba DKT2010SD Phone
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
How to forward incoming calls
There is a feature that most dealers do not activate called "Voice Mail Transfer" which transfers an incoming call to a person's (or department's) voice mail box. Forwarding calls to someone's mailbox is not possible without special programming by a certified dealer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Oct 08, 2008 | Panasonic KX-T7633 Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Panasonic KX-TG6841B DECT 6.0 Cordless Phone Logo
140 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
