Question about Lands Phones
Gigaset S79h/793 dead after changing batteries
I have 4 Gigaset S79H DECT handsets. Three of them when batteries dead and no longer holding a charge, I put new charged batteries in and phones are dead, only on/off and speaker key lights when press on/off and even after 10 seconds will not switch on. Fourth handset all OK. Gigaset tech help useless. It is too much coincidence (1 in a billion?) that 3 phones all go dead batteries and cannot work when all 4 only 16 months old and all within a few weeks of each other. How to fix please. Brian UK.
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
PyroPCMan
  • 405 Answers
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Posted on Mar 12, 2008
SOURCE: BT Studio 1000 4 handsets
hi problem with bt studio 1000 phone changed battery and phone still not working just a hi pitch sound when you press it .
please can you help me.
Posted on Oct 27, 2008
richa33
  • 71 Answers
SOURCE: DECT 225 - Ring tone etc. no longer works on 1 phone
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Posted on Jan 21, 2009
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Posted on Feb 19, 2009
I have a Siemens Gigaset A420 A Trio obviously three handsets.
Chargeable and non-rechargeable batteries are not interchangeable.
Aug 02, 2016 | Siemens Gigaset A420a Trio Dect Cordless...
There is no caller identified
Contact your phone company and ask them to enable 'Caller Display'. Usually there is a charge for this service.
Jan 15, 2016 | Siemens S79H Gigaset Expansion Handset for...
How do I increase the number of times the phone rings?
I don't think u can, after 25 rings it usually goes to answer phone automatically, if its going to answer phone b4 that then turn answer phone off the automatic setting.
Apr 04, 2015 | Siemens S79H Gigaset Expansion Handset for...
I am looking to buy a A495H base Gigaset unit to work with my 3 unit A49H phone set
Most modern Gigaset units work together.
I have a pair of gigaset 300 phones and three newer models, and a BT Diverse 2000 phone, all talking to the same DECT base station (a VOIP N300IP).
Feb 12, 2015 | Siemens Gigaset A495-4 4 handset cordless...
The lights on the base station are not working. Yes, I have checked the owners manual.
The power supply of the base station is working correct? the cable from the power supply is not broken? and the cable from the power supply is inserted?
Just a few questions, things I would start with when my base station wold not have any lights.
Oops the base station of my Siemens Gigaset S79H does not have lights.
Jul 22, 2014 | Siemens Gigaset 8825 Cordless Phone
I have a siemens 4000 handset and I like to register it to a ssiemens 4215 base. Is that posible? Please help.
Yes. All DECT compatible handsets will register to a DECT compatible base unit.
If you have the manual for either phone, just follow the instructions.
If you dont, some manufacturers do have some odd quirks to the registration process, but most follow the following.
Look on the bottom of the base unit - there should be a 4 digit number somewhere. There will probably be lots of other longer numbers and bar codes also, but these are unrelated.
The base unit needs to be put in to registartion mode - usually done by either switching it off, waiting about 30 seconds, and then switching it on. Or, press and hold the base unit's page / find handset key. NB. the base unit stays in registartioon mode for about a minute, so if you dont complete the handset steps before this time, you have to start again.
Somewhere in the handsets menu will be a register handset option. On selecting this it will then ask for the 4 digit number above. Enter this, and after a short wait, the handset will be registered. Remember, this has to be done before the base unit times out.
Also note; base units can only register 4 or 5 handsets (depends on manufacturer), so if you've already got this number, you'll have to de-register one of the others first.
Sep 29, 2009 | Siemens Gigaset 4000 Phone
Problem with my Panasonic phone cordless handset.
Wow, that's a great record for any cordless phone! The battery probably only needs to be replaced. The battery can no longer hold a charge.
Apr 18, 2009 | Lands Phones
Gigaset 8800 PIN reset
  1. Turn the handset off by pressing and holding the PWR key.
  2. While holding down the keys 1, 4, and 7, turn the handset back on.
  3. It will display "Handset Service".
  4. While this message is displayed, type in the numbers 4 6 8 5 4 6 3 (the word "hotline") on the number pad.
  5. The phrase "Settings Reset to Default" for a second or two and the handset will power itself off.
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
Dec 26, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
