Question about Briggs & Stratton Garden
I have a Yard Machines/ Briggs & Stratton 675 series 190cc lawn mower. It started this morning then stopped. I replaced the spark plug now the pull/start cord won't pull, what could be the problem.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
CHECK THE OIL. If oil level gets too low, the engine may seize due to excessive friction. Check the safety interlock cable for proper operation. Check under the mower for anything that may prevent the blade from turning. If the mower hit something hard like a stump, tree root, or a large stone then check the woodruff key where the flywheel slides onto the crankshaft (there is a notch in both the flywheel and the crankshaft where this key fits). If the notches are misaligned, then the key is sheared. If the key is sheared, remove the flywheel, replace the key, reinstall the flywheel.
Posted on Apr 24, 2015
  • 79 Answers
SOURCE: 190cc 3in1 briggs and stratton mower wont start...
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
#1 Taper
  • 1041 Answers
SOURCE: Craftsman 675 Torque 190cc 21"
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
Posted on Aug 13, 2011
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
If I haven't added Stabil to the gasoline for my Craftsmen 675, will that keep it from starting?
Ethanol gas can gum up the fuel system if left in unit for to long from now on use ethanol free gas in all small engines
Jun 22, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of battery does it take
Mowers don't typically take batteries. Possibly riding mowers might, but not push/self propelled mowers. They run off a spark plug and gas and that's it.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Garden Logo
132 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
