Question about IBM Wheelwriter 1000 By Lexmark Electric Typewriter
Why does my typewriter keep shutting it self off only seconds after it is turned on?
  • 453 Answers
Most of the tie this is caused by a bad power supply
Posted on Apr 23, 2015
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
How do you clear everything on the typewriter, and set to "default" settings?
Switch the machine OFF. While holding down the Margin Release key switch the machine back ON.
The machine should start printing a pre-programmed "self-test."
Switch the machine back OFF...give it 5 seconds then back ON again and you are back to Factory settings.
Sep 09, 2010 | Nakajima AE-740 Typewriter
My typer writter keep reseting it self and i cant get it to type the correct letters how do i reset it properly
If the spokes of the P/W are not damaged or getting tangled in the ribbons you probably have a broken P/W homing pawl. You need a tech.
DickyO
Aug 30, 2010 | Brother GX-6750 Typewriter
The power only stays on for a few seconds.
Check for forgien objects on or under the PC board if that dosen't do it you will probably need a tech.
DickyO
Jul 27, 2010 | Lexmark Wheelwriter 1000 Typewriter
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
Is there a 'reset' to factory default or a clear all settings/memory functions for this typewriter? Not sure what has been set, saved or activated. Would like to 'start over' if that is an option. Thank...
While holding down the Margin-Release key, switch the power back ON....... The machine will begin to print a "self-test".
It will keep on printing the self-test until you switch the power back OFF. After only 1 line of self-test you can switch the machine OFF.
Wait 5 secs, switch the machine back on, and you will have cleared memory.
Sep 09, 2009 | Nakajima AE-740 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Projection TV keeps shutting off
Good Day, checho3435;
Try this to help to narrow it down:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Day, big IRISH. back.gif
Jul 30, 2008 | Mitsubishi WS-55807 TV
CARRIER WON'T RETURN BACK TO THE CENTER
make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Dec 20, 2007 | Brother GX-6750 Typewriter
IBM Wheelwriter 1000 By Lexmark Electric Typewriter Logo
57 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
