Question about OKI Office Equipment & Supplies
Replaced drum. Now I have an Err 106 with 3819 under it.
My night hawk carbon monoxide reads L6. Then Err.
Lb (rather than L6) indicates a low battery. You need to replace the 9V battery in the carbon monoxide detector. The Err suggests an internal error but could just be due to the low battery.
If the Err persists after you replace the battery, press the peak level button (the right hand button) and check for an additional error code. If the Err message continues, replace the Night Hawk unit. If the unit is still under warranty, contact the manufacturer. Most of these units have a 10 year warranty. There are several models available from Kidde. The manual is available on the product site. For the KN-COPP-3 Night Hawk carbon monoxide detector, the documentation is available here: http://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-copp-3/ . Click on the Documents tab. The manual for the KN-COPP-3 999-0100 is here: http://www.utcccs-cdn.com/hvac/docs/2001/Public/06/User_Guide_KN-COPP-3_900-0100.pdf .
I hope this helps.
Dec 12, 2016 | Night Home Security
How to clear err m2 konicaminolta
You can clear it @ TECH. REP MODE --> Maintenance counter, but i advice you to replace 1st the consumables M2 means your consumables (Drum, Developer, Cleaning blade, Cleaning pad & Drum charge corona) already reach its life.
Oct 17, 2014 | Konica Minolta bizhub Office Equipment &...
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
I have a problem of system error of copier ir 2000. how can i solve it?
can You be specific by mean of which system error? Like E100? E000?, E001....
Few examples of most common errors:
E100 - Laser trouble - change the drum unit ( complete drum unit )
E000/001 - fixing trouble - try to reset the error under service mode - procedure: press MENU and #, with > key go to CLEAR and OK, find ERR and OK, turn off and back on - if it helps you solved the problem, if not you need to change the thermistors or the fixing lamp, because you have low/high temperature problem.
E019 - waste toner full - remove the drum unit and open the corks on top of the unit and empty/vacume waste toner out.
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
Nashua tech err cod SC 320
Basically, the code means that the Primary Charge cora is not charging the OPC drum correctly. You may have a bad or dirty corona unit or a old or damage OPC drum or a bad power supply.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
E000 system error - looks like we have to replace the drum unit, however quotations to do this range from US$700+ to US$1000. Do you have any suggestions for a company on-line that would have a drum unit...
firstly these isnt drum unit fault, E000 means fixing temperature trouble. The drum unit fault is when you have streaks on copy.
For drum try on e-bay or find local KATUN representative for cheaper Drum.
You can try to clear error, do next:
press MENU and #, select CLEAR, ERR and OK, if not helps these means that you need to change the fixing assy.
Sep 08, 2010 | Canon Image Runner 1630 Copier Copier
Maytag A511 has worked faithfully for 26 years.
Either the engine or the drum bearing are worn out and the rotor/drum is touching the stator/tub. It's normal wear and since replacement parts are no longer fabricated i think it's time to buy a new one.
Jan 30, 2010 | Washing Machines
It says err. on screen and beeps every 30 sec
An intermittent chirping every 20secs and an ERROR message 1.e. err indicates COMPONANT FAILURE and the appliance should be returned under warranty if still in force for replacement.
Oct 12, 2009 | Kidde Nighthawk Combo Gas/co Detector
Cannon IR 400S Copier
1-en front door look inside and see if there are black rings around the shiny Drum cylinder, if yes replace drum blade (may have to replace drum also).
2- if lines only come when doing from ADF then lift top and clean the small strip of glass.
Sep 13, 2008 | Canon imageRUNNER 400S Copier
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
