Question about Clarion Caa-355 6-Disc CD Magazine F8vf-18c833-Ae F8vf-18c833-Ad 6CD
Since my clutch was fixed my magazine will not work, it goes in a makes a noise then it pops back up, i have taken fuse for it out,popped it in , soon as fuse replaced it pops up,
Magazine was not in car when clutch removed, cant find code system if any
  • David Whitby
    David Whitby Apr 23, 2015
    my car is 55 plate peugeout 206
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
My radio fuse keep popping I checked for coins in the lighter socket and it was nothing there it was doing great and it happened all of a sudden have anyone had this problem and if so how did u fix it
When you pop fuses like this do not I repeat do not up fuse sizes by pass fuses your creating more work for yourself. Popping fuses like this means there is a direct short to ground some where. You need to check all your wiring on that fuse circuit and components hooked to it for where its grounding out.
Jan 16, 2014 | 2003 Acura 3.2TL
1998 mitsubishi eclipse front end problems?
This query is nothing whatosever to do with Cameras.
Oct 01, 2017 | Cameras
2001 silverado 2500hd a/c HEADACHE
There is a good chance that the electro magnetic compressor clutch is bad and will need to be replaced. The compressor is good, but the clutch system has a short in it at the compressor's clutch, which is causing your fuse to blow.
Test the connection at the clutch for a short if you have a multi meter. If it shows you have a short, then replace the electro magnetic clutch solenoid.
Thank you for using fixya and be safe.
Jul 17, 2010 | 2002 Chevrolet Silverado 2500HD
2004 Blast: Clutch makes a popping noise like its still turnin...
Nature of the beast. Might have a lumpy clutch disc. Wouldn't worry about it.
May 18, 2010 | 2004 Buell Blast
I have a Mazda 6 5sp Manual, Crackling/Popping when stopped.
Could be something jumping around in the exhaust. Is your catalytic conv in that area?
Feb 19, 2010 | 2007 Mazda MAZDA6
Clutch pedal went to the floor but did not come back up. Heard something 'pop' when pushing in clutch last night. Got home, then tried to start car this morning and clutch made a 'pop' sound again when...
there is a plastic clip that connects the clutch pedal to the rod that goes to the master cylinder, chances are that it let go. Bad thing is that it is only available from GM along with the rod. It is around 50
Oct 16, 2009 | 2003 Oldsmobile Alero
Electric stapler won't staple; Panasonic as300 will fire but no staples come out and I do not see any jammed staples when I open the cassette.
On the side of the stapler are the instructions - no joke - stick a flathead at the lip of the metal striker and push the flat head up - while pushing the realse at the back - use A LOT of force - that is how ours popped open. It was jammed in the back with several staples that were not visible as a jamb in the front where the staples come out. the whole magazine will pop out when it is freed.
Sep 13, 2009 | Office Equipment & Supplies
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Clarion Caa-355 6-Disc CD Magazine F8vf-18c833-Ae F8vf-18c833-Ad 6CD Logo
64 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
