Question about Carrier Heating & Cooling
My carrier comfort zone ii doesn't seem to kick on heating our cooling cycles in auto it only does when I actually switch the mode over to one of those settings is this a bad tstat?
    Genius:
  • Carrier Master
  • 1,363 Answers
Sounds like it.
Posted on Sep 06, 2015
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
farfield
  • 462 Answers
SOURCE: Carrier Comfort Zone ii - trying to find user manual
Your description leads me to believe you have 2 thermostats. How long have you lived in the house? Did it work for you lately? Sometimes its just the door switch. If you have to remove it to change the filter or had it off for another reason hold the switch in by hand and try it. then check the door for correct channeling in the grooves provided and see if this is it.
Posted on Mar 10, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
  • 22 Answers
SOURCE: Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Posted on May 06, 2010
walesarumi
  • 6993 Answers
SOURCE: Comfort Zone carrier Unit:
the answer is yes. It will work. They are almost the same thing with slight difference.
You can go ahead and replace the old interface with the new style thermostat.
I wish you good luck.
Posted on Sep 10, 2010
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 15, 2017 | Heating & Cooling
Good Morning: The display on our Carrier Comfort Zone II t-stat shows error code "E6". The unit is on auto and should be heating, as it is 30 degrees here in northeast Florida!!! The unit...
If the compressor is running, this is probably a defrost timer error. I am assuming this is a heat pump. I would turn it off and let it completely defrost, which will take awhile, maybe hours, if it is that cold. If it repeats, you will need to get an A/C tech out to trouble shoot. The biggest problem with heat pumps is that they don't work well when it is cold outside.
Oct 13, 2017 | Heating & Cooling
Box on the wall. Push buttons
mode will be heat, cool, or automatic. cool will show a snow flake flashing. Heat will show a flame and auto will switch from heat or cool by itself. Usually the auto feature does not work well as one is unable to set the heat and air where they are comfortable on both
Jul 27, 2010 | Carrier 38CKC036 Air Conditioner
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Thermostat issue with comfort zone II.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Jan 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
Heating & Cooling Logo
104 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
