Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Posted on Jul 04, 2016
2 Suggested Answers
  • 46362 Answers
SOURCE: I have a Toro the master commercial zero turn mower that won't engage the blades it runs but I can't turn the blades on
there could be a fuse blown or a wire broke off the clutch .
Posted on Jul 20, 2015
How do i fix my zero turn mower, will start,if blade knob is turned on kills engine, will not move with sticks when running , key will not kill engine.
this sure sounds as if you have a seat switch issue , this is a safety device to make sure theres an operator that weights more than 115 lbs in seat , the blade engauge problem and non movement tells me this
May 06, 2015 | Toro TimeCutter SS5000 zero turn mower
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro timecutter42 blades squealing and won't turn
just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Toro Zero Turn 50" mower with a Kohler 16HP engine. My PTO switch melted
pull the wires of of the pto in case it is shorted check charge at battery tomake sure wires havnt rubbed through
Feb 10, 2013 | Toro Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
128 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
