Question about Life Fitness Exercise & Fitness
I have Life fitness T5-0 show motor common error
Send me my email address
4 Suggested Answers
Solo4665
  • 53 Answers
SOURCE: Cannot Send Email to Anyone!
Also, it looks like Yahoo are now checking the verification of your account before you can use the SMTP service.
You need to do this..
http://help.yahoo.com/l/us/yahoo/mail/original/manage/sendfrom-07.html
Posted on Dec 10, 2008
Ezrahite
  • 2632 Answers
SOURCE: I can't access my email
Yahoo has been upgrading the servers and ran into difficulties, many are having the same problem. There are many issues at this time. They hope to have it fixed soon, In the meantime, you can use one of these links to access your mail, it's basic, no frills, but it works.
US:
http://us.m.yahoo.com/p/mail
UK
http://uk.m.yahoo.com/p/mail
Other
http://id.m.yahoo.com/p/mail
Not a guarantee these will work at this time. But you can try. This is not affecting some accounts, depends on which server you are on.
Thanks for using Fixya.
Posted on Apr 28, 2011
petewarr45
  • 155 Answers
SOURCE: Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Posted on Feb 22, 2015
Testimonial: "Peter Warr Hassall, i am very disappointed by your answer!"
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
Life Fitness 9500HR Console Reads Motor Command Error and the Red Led #1 is not flashing.
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
May 30, 2014 | Life Fitness 9100 Next Generation...
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
AC/Heater?defrost switch
think that's a motor driven door ,not vacuum like the old days,if you listen real close ,key on engine off ,under the dash ,center when you change the switch ,you should hear the motor run,if not,it's most likely the motor ,pricey little things too .
Jan 24, 2014 | 1998 Chevrolet S-10 Pickup
Almost all of my friends can't send me an email.Error Always show this on their email account every time they send me an email. Technical details of permanent failure: Google tried to deliver your...
God bless, try to put the your friends email address on your contact then send them an email for them to reply to, also check your inbox and delete some messages
Mar 23, 2011 | Yahoo Mail
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Can receive emails but cannot send emails
Send problems. There are several common causes of problems with sending email:
  • Mail queued. If you appear to be able to send email but it never arrives, it may be in a queue. Some applications put email in a queue when you send it, and the user has to manually send all queued mail to actually transmit it. Check your File and Edit menus for any queues, and also check the status of the email in the Out mailbox to see if it was actually sent -- if not, send it again.
  • Send on check. This is a common problem -- many email servers are configured to use the password authentication involved with checking mail to allow the sending of mail, and therefore require clients to check for mail at the same time or just before sending mail. If you get an intermittent error message and can send at some times and not others, make sure the option "send on check" is enabled in your email settings. As a temporary fix, you can often solve the problem by manually checking for mail shortly (a few seconds or minutes) before sending mail. This problem can also produce the message "relaying not allowed" described below, for much the same reason.
  • Relaying not allowed. Many Internet access providers require clients within their network to use their own servers for sending mail, as a policy intended to cut down on email spammers sending spam through other provider's servers. If you have more than one email address and can download mail without problems from a POP account with a different domain name than is used by your Internet access provider, but get the error "Relaying not allowed" when you try to send, then you probably need to set the outgoing SMTP server address to the mail server of your Internet service provider, instead of your email provider. Search your Internet network provider's home page or call technical assistance to obtain the address of their SMTP server, and enter it in your email client settings (first copy and save your existing server setting in case you need to set it back). This error message can also be produced by the "send on check" issue described in the bullet above.
  • Server down. If you can do a successful connection check, and the above suggestions don't help, and a recipient continues to say that email sent from you does not arrive, and you are certain their address is spelled correctly, then one of the email servers between you and your destination is likely down. Blocked email is typically cached and sent when the missing server comes back up, usually within a few hours or days. If the problem persists and you can successfully send to other email addresses, then the email provider of your recipient is likely having a problem -- you should contact them by phone and ask them if they are getting email from anyone else, request they send an email to you, and if necessary suggest they do a connection check from their end to help diagnose the problem.
This is from this webpage.
http://www.livinginternet.com/e/et_connect.htm
Feb 13, 2009 | NetGear RangeMax WPN824 Router
Exercise & Fitness Logo
66 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
