Question about Life Fitness T5-0 Treadmill Fitness Running Walking Exercise Equipment Gym 95t
Why does it show motor comon error? - Life Fitness T5-0 Treadmill Fitness Running Walking Exercise Equipment Gym 95t
    Novelist:
  • 145 Answers
Hi There, this leads to a failed lower board or board set. If you have 2 lower boards together in the base they should both be refurbed at the same time to avoid one taking the other out. Good Luck.
Posted on Jan 03, 2017
  • abhijeet shinge
    abhijeet shinge Jun 18, 2018
    I HAVE SAME ISSUE WITH MY MACHINE ALSO AFTER REPLACING CONTROL BOARD BY NEWONE, DISPLAY SHOWING MOTOR COMMUNICATION ERROR
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Electronic card malfunction. You need to change the mosfet material on it.
HOW TO REMOVE OR REPLACE ICE MAKER FAN
No, there is a different error code if the control board is bad or there is a wire connection issue. The IF error is a comon error and either the fan needs to be replaced or something like ice is blocking the fan from moving. Check to make sure ice or frost isn't blocking the fan, and if it's clear, you need to just replace the fan motor.
Jun 30, 2016 | LG LFXS30766S LFXS30766S 36" French Door...
Taping in a 1999 firebird
by tapping do u mean ticking as if you were listening to an old sowing machine?not to worry very comon with these cars i know i had one do to engine design it is comon for these motors to make noise like that they use differnt kinds of metals in this motor an shaved parts to meet emmisions the noise should get quit after it has warmed up why u might ask because when motor is cold the internals in the engine are one shape as it heats up it either expands or contracts to take up any play internal parts like i said very common and does not effect the performance of this vehicle however if after warm up sound remains or gets louder or makes noise with acceleration could be more severe i fixed one were a lifter collapsed an just needed replacement if you are concerned and have no automotive knowledge have a dealer check it over .but go to more than one garage lots of scam garages out there just remember these motors are aluminum and very sensetive. fyi cam an lifter will only cost from 800-1500 but if motor blows your looking at 5000 easy
Aug 18, 2014 | 1999 Pontiac Firebird
Why did it lose power during use
Worn brushs in electric motor, it is comon in
units used much, maybe a bad or burnt switch
Jun 01, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Discs not responding says error
comon error... it is probably upside down...try flipping the dist over!
Mar 08, 2010 | Nintendo Wii Console
Driver seat (power) will not go down. is there a manual release?
hi more than lickly the motor has siezed check the fuse's has this is a comon fault. if if t has blown the motor in the seat has blown
Jan 25, 2010 | 2000 Volvo S40
Windshield washer fluid won't spray
It is comon for the washer fluid pump to fail. I would also check the bottle for leaks it is comon for the battery to leak and damage the pump and the bottle.
Roy
Oct 31, 2009 | 2001 Chevrolet Silverado 1500
Change motor speed
if it is afixed speed system, the taps on the motor are: black = hi speed
yellow = med hi
blue = med low
red = low
you may not have a yellow
white is always neutral or comon
Jun 22, 2009 | Lakewood 007 Floor / Box Fan
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Life Fitness T5-0 Treadmill Fitness Running Walking Exercise Equipment Gym 95t Logo
98 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
