Question about Smeg Dishwashers
Can I remove clear cover at top of door showing make and model to clean built-up grime? Model PL 512
    Problem Solver:
  • 11 Answers
Yes it is removable however it provides additional protection from moisture damage. So after removal it could be more prone to scratching or moisture damage.
Posted on Jul 14, 2016
4 Suggested Answers
  • 76 Answers
SOURCE: vent cover removal from Kenmore 17252 dishwasher door, for cleaning
kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
Posted on Feb 07, 2007
  • 7 Answers
SOURCE: Neff Dishwasher
Telephone BSH 08705 543210 ask for spares department who are very good helping you with spares as long as you have all relevant serial and product numbers it can sometimes be difficult to get through because they are always busy, be persistent
Posted on Oct 09, 2008
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
My SONY NW-E002F mp3 walkman, 512 mb tells me
1.reset device.remove battery.and try again.2.clean MMC of dirty. good luck
Dec 05, 2009 | Sony Audio Players & Recorders
The 'inlet/outlet' red indicator light flashing, small pool of water collected under filter, but cannot get back of to clean it. Model is Miele G646sc
You might be able to reach if you take the sides off. Elect disconnect, open door, remove 2 cross head screws recessed at top of where door closes, push top cover backwards an inch then lift off. remove 2 screws at top of each side panel then the lower ones (4 a side) panels then lift off and you can see right across the bottom of the 'sump' including the float switch assembly. (which has no effect on switching on the inlet/oulet lamp on my d/washer.)
Nov 10, 2009 | Miele Premier-Plus Built-in Dishwasher
Model A 512 washer-water pours out from plastic unit on hose at top left after relay water line unit
Sounds like you need a new injector.
Remove the front cover (loosen the 2 Philips screws near the bottom, lift the front cover 90 degrees and pull back). Remove 2 bolts at each corner from to the top cover located up front. Remove the beach dispenser hose, tilt top cover up. The injector will be on the left.
Sep 29, 2009 | Maytag Washing Machines
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Door won't open
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
If yours is a DMT2420 or other counter top model that is built into a cubbly hole and surrounded by a metal grille (built-in kit), the kit will have to be removed, then the oven will slide out of the opening.
Once it's out, you can remove the outer cover and you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
The model tag will either be on the back or around the door frame or control panel frame, or maybe inside the cooking cavity.
We have several Dacor microwave service manuals at our site:
It's a pain, but for Dacor the parts list are separate:
Once you have the part number of the part you need, you can order by part number here.
(This site does not list Dacor by model number, only by part number)
Aug 03, 2009 | Dacor DMT2420SS Microwave Oven
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
G665 miele
Hi, I was having the same problem but with a G572 (that's about 10 years old) though this might help you still as i believe they're all built fairly similarly.
My problem is I would start the cycle and I could hear the motor in the pump turning however no water would enter the machine.
Open the front door and look at the sprinkler on the base. Underneath it is a small tower (about 3cm high) and it has a cap on top of it. Take the cap off (mine just pulled off) and clear any grime that has built up inside of it. Now try to use the machine. (while I was clearing the grime I could actually hear something neutralise, as if there was air pressured up behind the grime).
I hope this works for you.
Jun 23, 2008 | Miele 24 in. G665 Built-in Dishwasher
No Water entering machine at all.
It may be that the tray underneath the machine is full of water and this appears to activate the anti flood device and shuts off the water supply. If you remove the panel under the door you should be able to check. There are 2 screws to the side and 2 to the top of the small panel. I am uncertain where the water came from on my machine but this appears to have solved my problem.
Jun 22, 2008 | Miele 24 in. G665 Built-in Dishwasher
Ie problem on lg dishwasher
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
May 11, 2008 | LG LDF6810 Built-in Dishwasher
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Dishwashers Logo
87 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
