Question about Smeg Dishwashers
Can I remove the clear plastic cover at top of door showing Smeg and Model number to clean inside built-up discolouration?
  • 76 Answers
SOURCE: vent cover removal from Kenmore 17252 dishwasher door, for cleaning
kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
Posted on Feb 07, 2007
  • 121 Answers
SOURCE: Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Posted on Nov 07, 2007
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
  • 39 Answers
SOURCE: Bissell pro heat carpet cleaner clear cover removal
just lift it up probably suction holding it
Posted on Jun 29, 2009
Maytag317
  • 1136 Answers
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Posted on Jul 12, 2009
Can I remove clear cover at top of door showing make and model to clean built-up grime? Model PL 512
Yes it is removable however it provides additional protection from moisture damage. So after removal it could be more prone to scratching or moisture damage.
Apr 23, 2015 | Smeg Dishwashers
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
The ice dispenser rubber door or seal does not close allowing warm air back into the freezer and causing frost buildup. How difficult is that rubber seal to replace.
Remove the top freezer hinge cover and disconnect the plug there . This will remove power to the door . At the bottom of the dispenser cover , but inside the dispensing area , between the grill and the cover , insert a small screwdriver about 1 " in on both sides , and push down and inward , forcing the bottom of the cover outward . Do this carefully , due to plastic tabs on the dispenser cover . After bottom is loose , lift upward , to release the top plastic slots of the cover . Disconnect the plug on the cover . Remove the 2 screws holding the dispenser housing , and slide forward . You should now be able to see the door flap , return spring and pin . You will have to see which part(s) are needed or what the situation is . Maybe pin slid out , maybe the clear plastic ice guide , connected to the dispenser activator arm , broke loose , obstructing the closure of the door flap . Come back with your findings and a model number , and myself or another expert , will be glad to give you part numbers .
Sep 14, 2009 | Whirlpool Refrigerators
HI I HAVE A SMEG OVEN MODEL NUMBER SA995XR I NEED THE INSTRUCTRION MANUAL JUST TO SEE HOW TO WORK THE SELF CLEANING OPTION THANKS
Hi I have just installed this oven SA995XR-5 yesterday and have the manual. It doesn't say anywhere it is self-cleaning, just good old elbow grease. Below is what is in the manual.
*I have a question for you. Does the cooling fan in your oven go all the time or does it stop some time after the oven has been turned off (which is what the manual indicates it is supposed to do)?
7.Cleaning and Maintenance
Before performing any operations requiring access to powere parts, switch off the power supply to the machine.
7.1 Cleaning stainless steel
To keep Stainless stell in good condition it should be cleaned regularly after use. Let it cool first.
7.1.1 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
7.1.2 Food stains or residues
Do not use metallic sponges or shapr scrapers: they will damage the surface.
Use normal non-abrasive products for steel and a wooden or plastic tool if necessary.
Do not allow residues of suraty foods (suc as jam) to set inside the oven. If left ot set for too long, they might damage the enamel lining of the oven.
7.2 Cleaning of the oven
To best oven upkeep clean regularly after having allowed to cool, Take out all removable parts
  • Clean the oven grill and side guides with hot water and non-abrasiev detergent, Rinse and dry.
  • The oven should be operated at the maximum temperature for about 15/20 minuytes after using specific products, to eliminate the residue deposited inside the oven.
  • For easier cleaning, the door can be removed.(8.2)
7.3 Door Glass
The door glass should always be kept clean. Use absorbent kitchen paper to clean. In case of tough spots, clean with a damp sponge using regular detergent.
8.2 Removing
Hold the door on both sides with both hands near hinges (A - there is a diagram showing this is the top hinge) and raise levers (B - this lever is a little arm attached to bottom hinge. Flick it up until it catches into groove on upper hinge. Its quite uncomplicated). Lift up the door forming an angle of about 45 degrees and remove. To refit, slide the hinges A in the grooves, drop door and release levers B.
8.3 Oven door seal
To permit thorough cleaning of the oven, the seal may be removed. Before the seal, take off the door as described above. Once the door has been taken off, left the tabs at the corners as shown in the figure.
After cleaning, refit the seal with the longer side horizontal and insert the tabs into the appropriate holes starting from the top ones.
Jan 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Dishwasher button broken
I am trying to fix the same problem. There is a clear plastic frame around the controller that has small plastic arms that the button pushes against. You will find that it has broken off and fallen inside the door. I managed a temporary fix by unscrewing the door panels finding the buts. Remove the clear frame it clips to the controller once you unscrew it from inside the door. I then used super glue to glue it back together. Fix is temporary only lasted 3 weeks and broke again. What you need to do is find a replacement clear frame.
Apr 20, 2008 | Dishwashers
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Apr 21, 2007 | Smeg DWI614 Built-in Dishwasher
Dishwashers Logo
52 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
