Question about Nuwave Precision Revolutionary Portable Induction Cooktop
I used the wrong pan on the Nuwave induction cooktop. Now it won't work. Is this something I can fix?
YOUR ANSWER WAS VAGUE. DOES THIS MEAN I CAN STILL KEEP USING IT?
dont keep using it
if that Miele Cooktop induction type or other types
is NOT working the way the user manual says its should with the correct pots and pans
Sep 16, 2016 | Miele Cooktops
Got wrong rings or something my saucepans and pans are destroyed with black soot after cooking ?
If you're using a gas stove, the gas air mixture is wrong. If you're using electric or induction, it's the residue left on the pans when cleaned.
Sep 20, 2015 | Cooktops
Salton induction portable cooktop bought 8 months agosuddenly stopped heating up ,all the indicators turn on normally. what is the reason
induction needs the right type of pan /skillet of they will never work Steel content has to hold onto a magnet .
Feb 17, 2015 | Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to...
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Jul 02, 2017 | Cooktops
How can I fix at home the product described?
I would file a claim with the airline for damages. There are no parts available to repair those units yourself.
Nov 27, 2017 | Hearthware NuWave Precision Induction...
Q1 1210-017-199
An E1 reading typically means that your PIC does not detect
cookware on its surface. This can occur for one of two
reasons.
1. Have you placed a pot or pan on the unit? The induction
coils contained within the PIC will only work when they are
in direct contact with a piece of cookware. To maintain your
appliance's effectiveness, always ensure that it rests on a flat
surface and that contact is consistent with your cookware.
Refer manual at this sitehttp://www.nuwavepic.com/resource/pdf/NuWave_PIC_Manual_and_Cookbook.pdf
May 29, 2014 | Hearthware NuWave Precision Induction...
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Small pans do not work.
are you sure the small pan is made of conductive metal , ( used the magnet test ?)
Dec 13, 2008 | AEG 23 in. 67600KF-N Electric Cooktop
Nuwave Precision Revolutionary Portable Induction Cooktop Logo
99 people viewed this question
Top Nuwave Cooktops Experts
Paul Carew
Are you a Nuwave Cooktop Expert? Answer questions, earn points and help others
