Question about Xerox Office Equipment & Supplies
On my Xerox 7132, How do I remove the IBT belt?
  • 2072 Answers
SOURCE: fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Posted on Aug 13, 2008
  • 20 Answers
SOURCE: How to replace the ibt belt or where to buy ibt belt assamble
I have got the new one it cost about $400 usd i you want i show you how to change. Greetings
Posted on May 17, 2009
SOURCE: xerox 242 fault code 042-326
foult code 093-317
Posted on Apr 27, 2010
wrinaldo
  • 185 Answers
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit Item, Inc.
Posted on Dec 02, 2010
emissionwiz
  • 76109 Answers
SOURCE: 089-311 error code for xerox copier #7132
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor
Posted on May 01, 2012
Xerox error 089 311
That error signfies a problem reading the IBT belt patch. Check patch and clean and inspect for scratches. It's on the inner side of the transfer belt. If problem still persists after cleaning, replace IBT belt, part number 064K92402.
http://www.iteminconline.com/itemdesc.asp?ic=064K92404&eq=&Tp=
Aug 25, 2014 | Xerox Workcentre 7132 Multifunction Color...
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
May 01, 2012 | Xerox Office Equipment & Supplies
How to change ibt belt and get the machine fault code 004-346 removed on xerox 7345
Whit Item, Inc.
Nov 19, 2010 | Xerox Office Equipment & Supplies
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
Error 3-380 dc 12 xerox
its problem of IBT belt sensors
two silver colour patchs held on ibt belt check that patches its has any dust
or damage
replace that patches
Mar 06, 2010 | Xerox DocuColor 12 Color Copier
How do i replace an accumulator belt on a Phaser 7760
  1. Open the Front Cover.
  2. Release and move the IBT Cam Lever down.
  3. Open the Right Side Door.
  4. Removing the IBT Belt Assembly
  5. Lift the Accumulator Belt Locking Level and pull the Assembly out to remove.
  6. Use Handle to transport IBT Unit. Protect the IBT Belt Assembly from
  7. On the front, there will be 2 torx screws on a plastic strip. Remove those and the cleaning assembly.
  8. There are 2 spring loaded clips. One on front and one on back that release the spring tension on the roller. You have to press them in and press the locking tabs.
  9. Then go around the frame and remove the screws in order to "fold" the assembly and remove the belt.
  10. Be very careful not to bend the bracket near the bearings or you will have belt tracking faults after replacement.
  11. Be sure you install the belt in the correct direction. There is a silver patch on the belt that must be on the inside of the belt assembly when installing. Look at the old one before removing to determine the orientation of the belt.
Jan 13, 2010 | Xerox Phaser 7760 Laser Printer
I need to know if the Transfer Belt Unit for the XEROX 7232 (newer model) PN 064K92790/1 can be used in the 7132 (older model) instead of the # 064K92402/4. I have one and would really not have to purchase...
What you have is a 7232 IBT belt assembly. The internal workings of the assembly work with the 7232 and 7242, but not the 7132 - they are different model series.
Aug 28, 2009 | Xerox Office Equipment & Supplies
106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
