Question about Frigidaire GLTF2940ES Front Load Washer
How do change or clean out the waterpump - Frigidaire GLTF2940ES Front Load Washer
  • Frigidaire Master
  • 473 Answers
There is a front access panel below your door that is held in place by 2 screws at the very bottom edge near the floor. Remove the screws and access panel. The drain pump on that model I think is at right front corner. To remove or clean it---unplug washer---unplug 2 wires to pump---remove/loosen 2 big hose clamps and pull rubber hoses off---and then remove 2 mounting screws holding pump to washer floor. Reverse procedure to reinstall.
Posted on Apr 23, 2015
Waterpump
pull out your coolant res.
pull off your belt.
you will see the old waterpump.
remove all four bolts.
clean off gasket off waterpump mount on motor.
place gasket.
install.
Jun 30, 2012 | 1999 Pontiac Sunfire
Leaking anti freeze. But not from the radiator.??
If it is coming from the front of the engine and almost dead center, then probably the waterpump is going bad. The waterpump is located underneath the timing covers (2 pieces), and requires you remove the timing belt to change it. I can email you a procedure for removing and reinstalling the timing belt if you wish. Send a request to sernst@insightbb.com if you decide to change the waterpump.
Mar 28, 2011 | 1997 Isuzu Rodeo
Waterpump is it b 4 the timeinbelt
waterpump is driven by the timing belt. Therfore when changing the timing belt, you must also replace the waterpump. It will be too much time consuming effort to replace one or the other. The labour calls for both these items to be replaced. Most shops will charge about$300 -500.0 plus both parts for this service..
Mar 02, 2011 | 1998 Plymouth Grand Voyager
I have a 1994 oldsmobile cutlass cierra and the waterpump is leaking and i need to know what tools i will need to change it out
wrenches and sockets the correct size and something to clean off the old gasket, the waterpump is probably the only easy thing to change on this car!
Jan 14, 2011 | 1994 Oldsmobile Cutlass Ciera
Procedure on changing waterpump
  1. first drain the cooling system.
  2. loosen bolts on the waterpump pulley and remove the inner fender cover on the pass/side.
  3. remove the surpentine fan belt, note; make a diagram of the belt routing so belt will go back on the right way.
  4. remove the bolts you loosened on the pump pulley, use a pry bar to pry engine back to have enough room to remove the waterpump pulley.
  5. remove the bolts holding waterpump, you will want a pan under the van to catch coolant when waterpump is removed,
  6. remove the pump and clean old gasket off the block and install new pump,
  7. reverse to install new pump and fill system with coolant allow engine to run until thremostat opens,hope this is helpful. heres a few diagrams of the waterpump and the cover and the belt routing, good luck and hope this is helpful.
Oct 27, 2010 | 2005 Dodge Caravan
Do you have to remove power steering belt pulley to change the water pump?
no, just remove the belt, then the cover over the waterpump then the waterpump pulley,NOTE; loosen waterpump pulley bolts before removing the belt,just loosen dont remove!,next is to remove bolts holding waterpump and pump comes out,9e51b2d.gif
Apr 10, 2010 | 2004 Chevrolet Impala
1996 cavalier overheating. I changed thermostat but seems like its not opening. Lower hose is cold but fan turns on. any ideas
Your next test should be checking the health of the waterpump. Even with a bubble in the cooling system, the bubble should not take up residence in the waterpump cavity and should pump some. Look for activity in the radiator after things have heated up. Do you see any circulation? If not, the vanes might have rotted off (rare problem). Before doing anything else, try to thoroughly clean the system, and replace the fluid with just water for further testing. I don't know how well the car has been cared for, so if nothing has been done to the cooling system since it was new, try taking the bottom hose off and look for sludge that has gathered there. Clean. Short of all that, disassemble the waterpump and look at it. After you've found the problem, of course replace the straight water with a mixture of water and the good stuff. (No straight antifreeze. More is not better because antifreeze is designed to work with water. Straight antifreeze has poor thermal conductance.) Good luck.
Feb 26, 2010 | 1996 Chevrolet Cavalier
Water leakking from 5mm hole on side of water pump ford transit 1997
This is called a weep hole and it indicates the rubber seal is now leaking antifreeze onto the waterpump bearing and it's only a matter of time before the waterpump falls change the waterpump.
Dec 31, 2009 | 1987 Ford EXP
Changing waterpump
Intrepid 3.5l is behind the front cover. Not fun, but can be done.
May 01, 2009 | Dodge Intrepid Cars & Trucks
Honda Accord 1995 temp sensor
maybe this will hel57436774p you
Feb 17, 2009 | 1995 Honda Accord
Frigidaire GLTF2940ES Front Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
