Washing machine fills up with water and wont drain and wont do a spin it just frezzes and then comes up with e21 need help on what to do
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage
Posted on Apr 27, 2015
  • 1294 Answers
SOURCE: Fisher paykel washer wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 21, 2008
SOURCE: i have a kenmore elite
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Posted on Dec 22, 2008
  • 2920 Answers
SOURCE: machine washes but ont the spins it wont kick the clutch in
yep the clutch is going out you are lucky it will spin at all
Posted on Jan 13, 2009
  • 240 Answers
SOURCE: wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Posted on Mar 16, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Keep getting E21 code on my Kenwood (K814WM14) washing machine. The washing machine is draining fine, however when filling with water it makes a bumping sound then goes to the E21 code
Is your water pressure fine? Is there water coming out of the waste hose? Make sure that the waste water hose is elevated at 20/30 degree angle. This did the trick for me.
Feb 09, 2016 | Washing Machines
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Zanussi 6hg 1400 rpm won't drain
My machine won't fill up with water and I noticed it started flashing e21 and its not spinning very well either what could the fault be
Aug 17, 2012 | Zanussi ZWF1430W Front Load Washer
E21 code
its probberly your filter blocked or you have a obstuction in your pump check your filter first as if it is blocked your machine will only part empty thus making your washing not spinning out properly
Nov 16, 2011 | Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washer stuck on wash n wont spin not filling up with water
If water is coming into your machine but not filling up then you have a siponing problem (draining and filling at the same time). Raise the drain hose up higher at the drain at the back of your machine.
Jul 09, 2010 | GE WBSR3140DW Top Load Washer
Wont spin
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Jun 03, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
Top Washing Machines Experts
