Question about Porter Cable Tools & Hardware - Others
E77 edge sander grease fitting. What type grease do I use?
    Problem Solver:
  • 18 Answers
Any good quality general purpose grease should suffice. If you want a more detailed answer, you need to provide a little more information than just E77 edge sander. Brand, full model number (not the name), etc.
Posted on May 10, 2015
How do you put sandpaper on a Craftsman 1/4 sheet sander?
If you have the sander that is in the picture (and I surely do hope that you do), I can help you.
Your sanding felt pad is square, and two of the sides, opposite each other, have a wire spring clip on them.
You lift the clip and rotate it and then you will have a opening under each of the spring clips to insert an edge of the sandpaper.
Cut the sandpaper to 3/4ths of an inch longer than the pad on both sides that are to slide inside the spring clips.
Insert one edge of the paper under one side, then snap the clip down in place.
Then, curl the edge of the other side of the paper with your fingers to fit under the other edge, and then snap that one down on the paper. Good to go.
God bless your efforts.
Nov 05, 2015 | Craftsman 1/4 Sheet Palm Sander
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
Hook sand paper will not stay on the disk of the 5" palm sander
The backing pad does not last very long on these hook and loop designed sanders, and the pad should be replaced when the edges of the pad look worn. If the edges are okay try taking a toothbrush and some degreaser (IPA or brake cleaner). Look for the replacment backing pads online or at a hardware store.
Feb 21, 2011 | Porter Cable Palm Grip R.O.S. With Kit Box...
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
Where can I get instsructions for the Dewalt DW411 Palm grip sander and also what type of sand paper do I get to fit it.
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Oct 05, 2010 | Dewalt DW411 quarter - sheet palm grip...
How do you change paper on a black & decker finishing sander 7404-04
Aug 14, 2010 | Tools & Hardware - Others
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
Tools & Hardware - Others Logo
51 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
