Question about Haier Refrigerators
The led light does nt lightening and also the refrigerator works but sometimes it doesnt works ?
I have a dell inspiron 560 with 6 wires from the front panel power switch. which wire is yhe positive for each set? the color for each set are as follows power switch colors are 1) blue and brown 2)power...
Led's only work one way, so it does'nt matter what colours they are. The led's that they connect to will only work when the plug is the correct way. You wont do any harm if they are wrong, you just turn them round. Plug them in one way and if the led for the hard drive does'nt come on then it's the other way. Same with the power light. The power switch when pressed just makes a momentary connection across 2 pins, so it does'nt matter which way, it's just like touching the pins quickly with a piece of metal.
Feb 11, 2012 | Dell Inspiron 560 PC Desktop
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
Fridge section doesnt work at all. lights and door alrm do. just wont get cold
some circuit problem in sensor, clean your ref first throughly inside and back. after that use it see what happen. be sure that the evaporator aluminum tube wire is not damage or punctured dent that may cause's a small hole led to leak the refrigerant.
Feb 02, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
Side by side, symbol for the opened door blinks- door closed
The door switch has gone bad or is intermittent. replace the door switch located at the top of the door at the hinges.
Feb 04, 2010 | KitchenAid KSSC48QMS Side by Side...
PRND123 indicator light go`s on & off
this display is what they call a LED they are prone to problems, u will need to remove the speedometer head and send it in for repair of the display module, about $200
Jan 06, 2010 | 1999 Chevrolet Silverado 1500
No LED light when connected to charger
LED light does nt hav to be on at all times yes it shows your coverage but it can be turned off its nt a major problem.
Oct 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Does not get cold; after a lightening storm blew the breaker, the refrigerator and freezer does not get cold. Lights and fan work.
Sounds like the main control may have been damaged. try unplugging for 5 minutes and then plug it back in. Other wise a service call is needed.
Aug 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
