Question about Ingersoll Rand Air Tools & Compressors
I want to find a cylinder head gasket for model p110dg
Number 12506055
    Top Expert:
  • Ingersoll Rand Master
  • 10,875 Answers
Water in spark plugs
Is the plug really clean? That usually means the cylinder head gasket failed. You would need to remove the cylinder head. (valve cover, intake manifold, timing belt/chain) clean off the mating sufaces, inspect mating sufaces for truness, possibly have them machined, install new head gasket, bolt down head to correct tourque, reinstall timing belt/chain, intake manifold, (install all new gaskets) and valve cover. It's a lot harder than it sounds, usually. Call at least 4 local mechs for a quote to replace head gasket on your car. Just a gasket kit alone could cost 90 to 300 bucks depending on your model. This is a major job. Google head gasket and your model and year , you may fiind youtube videos for you exact model or similar.
May 14, 2013 | Buick Park Avenue Cars & Trucks
1991 chevy s10 number one cylinder has antifreeze build up
spray from hose during heat soak after shutting off.
possible head gasket leak. leaky crossover between heads. or
cracked /broken head.
Feb 21, 2013 | 1991 Chevrolet S-10
1995 chevy blazer fouling on number 2 cylinder
with this issue , fouling can mean many things, i,ll assume, & i don,t like assuing at all, ? i,ll assume you mean missfiring inderperforming two different issues, two answers, (1) missfiring ,ok change all plugs and remove and overhaul number two injector, replace it,, (2) fouling,? under performing, this can have a few causes i,ll list all, pressure loss in cylinder due to either worn piston rings or valve seatings, or head gasket,?(a) piston rings, luckily this is probably not the problem as usually all 6 cylinders would be effected, (b) valve seatings , hope its not this as it,s a major opperation involving removing the cylinder head an totally reconditoning it, all valves cleaning and reseating, replacing vavle seals , new head gasket ,inlet manifold gaket , exhaust manifold gasket, a good mechanic can get away with changing only the head gasket, but that ain.t you,unfortunatly, so hope its (a) peter.
Sep 01, 2012 | Chevrolet Spark Cars & Trucks
2002 2.0 jetta is mixing oil and water
your cylinder head gasket was damage or your engine might have hole. But the number one suspect is the cylinder head gasket is damage
Sep 27, 2011 | 2002 Volkswagen Jetta TDI
I have a pontiac and i keep blowing head gasket on number one cylinder. I have installed new heads and gasket lasted about five years. I was wondering what the correct head bolt torque is for a 1995...
cylinder head bolts, step one;33 ft. lbs, second step rotate an additional 90-degrees (1/4 turn). do not put any oil or sealant on gasket. the gasket should seal itself if torqued properly.
Feb 27, 2010 | 1995 Pontiac Grand Prix
WHAT IS THE COST OF REPAIR ON A HEAD GASKET FOR A 1997 SATURN SC? THANKS, JOE
1.9L SOHC - head gasket set which includes all gaskets needed to remove cylinder head with thermostat runs about $150.00. Head mechine ( check for cracks and milled ) $145.00. Labor time to remove and reinstall cylinder head 8.5 hrs X shops labor rate.
1.9L DOHC - head gasket set and thermostat runs about $210.00. Head mechine $175.00. Labor to remove and reinstall cylinder head 10.7 hrs X shop labor rate.
Labor times per Mitchell labor book, this is a guide all repair shops used.
Jan 12, 2010 | 1997 Saturn SC
Head Gasket changed >>> if installed incorrectly or wrong model ?
Head gasket is not your problem when you had the top end of the engine rebuilt it was 2 strong and blew the bottom end out so meaning the cylinder has 3 rings if they leak or on leaks you get wash out in the cylinder and it will burn the oil. the lurching is OK as long as its not a clunking
May 10, 2009 | 1998 Toyota Tercel
Water in number 4 cylinder of suzuki sierra 92 model carby type
If you take out number 4 plug and look in the hole do you see antifreeze? If yes, then yes, replace the head gasket.
Mar 14, 2009 | 1992 Suzuki Samurai
Coolant over flowing while driving, not overheating, 2000 deawoo
change cylinder head gakate and check cylinder head that not bend from heat.
Jan 16, 2009 | 2000 Daewoo Nubira
Air Tools & Compressors Logo
146 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
