Question about Frigidaire GLTF2940ES Front Load Washer
Where is the pump located and what is the easiest way to get to it
  • Frigidaire Master
  • 473 Answers
There is a front access panel below your door that is held in place by 2 screws at the very bottom edge near the floor. Remove the screws and access panel. The drain pump on that model I think is at right front corner. To remove or clean it---unplug washer---unplug 2 wires to pump---remove/loosen 2 big hose clamps and pull rubber hoses off---and then remove 2 mounting screws holding pump to washer floor. Reverse procedure to reinstall.
Posted on Apr 23, 2015
Where is the water pump located on a 2013 chevrolet malibu lt
The water pump is located on the passenger side, up towards the front on the side of the engine. easiest way to find is to follow the hoses from the radiator to the pump which will have a pulley attached to it.
Sep 18, 2015 | 2013 Chevrolet Malibu
I had my oil pan replaced and now I have no oil pressure.
you need to prime the oil pump before runninning the engine, easiest way is to locate the oil pump drive and attach a drill to spin the pump so the oil gets around all the galleries
Oct 14, 2014 | 2005 Ford F-150 SuperCab
Location of the fuel pump relay on a 2002 jaguar xtype 3.0
No FPR fitted.
Works via fuel pump module.
Module powered from fuse 81 on diagram of fascia fuse box. This fuse gets its feed from the ignition relay.
dae5bb3c-0053-4ad2-8bb0-945413126f57.jpg a02d94cb-80b8-4f3a-8548-93247d9e0aa9.jpg
Mar 14, 2014 | 2002 Jaguar X-TYPE 3.0L
Where is the oil pump located on 1998 pontiac firebird
its in the oil pan easiest way is to pull engine remove pan and replace but there are methods of removal without pulling motor
Mar 06, 2013 | Pontiac Firebird Cars & Trucks
Where is the fuel pump located on a 1991 corsica?
The fuel pump is inside the gas tank.It's not the easiest job,but not impossible for a do-it-yourselfer.
Oct 08, 2012 | 1990 Chevrolet Corsica
Location of water pump on engine
The easiest way for you to locate the water pump is the follow the bottom radiator line from the radiator to the engine. Where it connects to the motor is the water pump. It should be on the front of the engine. Make sure you trace the lower radiator line that is about 1 and 1/2 to 2 " in diameter.
Nov 29, 2010 | 2001 Hyundai Sonata
Where is the fuel pump located. Is it electric or mechanical?
on the 97 neon u have to drop the tank its on the back passenger side of the tank just undo the straps and lower the tank and the pump will unscrew from the tank if the tanks plastic
Nov 03, 2009 | 1997 Dodge Neon
Location of the washer pump
It's in the washer fluid reservoir. (Held in by a rubber grommet at the bottom of the reservoir bag) Easiest way to get to the pump is to remove the reservoir. (One bolt)
Sep 09, 2009 | 2000 Volkswagen Golf
Need location of fuel pump on 2002 grand am
Remove the back seat, there should be a cover to remove allowing easy access to the pump.
May 15, 2009 | 2002 Pontiac Grand Am
Fuel pump relay location 1990 chevy subburn
One of the easiest ways is to listen for pump to cycle in tank "HUM" when someone cycles key to on. If you hear "Hum" pump is getting power. The other would be to swap it out with another in that area, with same # on it. Under hood, passenger side, on firewall usually. Should be at least one more relay there with same #. There are so many ways that manufacturers recommend for different vehicles, this is usually the easiest. If I can't test for power in & out of relay when key on, I'll go direct to tank sender & check for power there to be sure.
Apr 05, 2009 | Chevrolet Suburban 2500 Cars & Trucks
Frigidaire GLTF2940ES Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
