My copier gives error h401, what does it mean? Itried to start bu it gives b - 04 and then 534 Why?
    Top Expert:
  • Office Equip... Master
  • 47,683 Answers
No make no model no help can we give .SORRY
Posted on Apr 23, 2015
Error h401 on my duplicator
if you are using a colored drum, you need to change the value.. if black, just press green or start button then you are good to go. hope to be of help.
Feb 12, 2014 | Riso RZ220 Duplicator
Why is my riso EZ20 blinking H401
h401 is not an error.. it needs to confirm if the original to be scanned is colored or gray scale... first it will go to H101.. just press start, then H401 press start.. you can start doing your jobs. hope to be of help.
Feb 12, 2014 | Riso Office Equipment & Supplies
I observe code H101 and H401 on my Riso RZ 200ep.please tell me how to clear these
Go to http://www.wholesalewidgets.com/Ink-wont-print_b_2.html for free advise.
Nov 13, 2012 | Office Equipment & Supplies
I have an error code H401 on my sharp AR336 copier. Help please
H 401 means Heat roller low temperature detection. i.e. The temperature does not reach the
preset value within the specified time (3 min. in usual modes; 5 min. in curl correction mode.) after the power relay is turned on.
Possible causes
Thermister defective
Heater lamp defective
Control PWB defective
Thermostat defective
AC power supply defective
Interlock switch defective
Possible remedies
Check heater lamp for blinking with SIM5-2.
If lamp blinks properly:
Check thermister and its harness. Check thermister input circuit of control PWB.
If lamp does not light:
Check heater lamp for broken wire and thermostat for operation. Check interlock switch.
Check lamp control circuit of AC PWB and control PWB.
Clear the trouble with SIM14.
Jun 13, 2011 | Sharp Office Equipment & Supplies
We have canon copier ir 2016j, it started giving error E007, how can i solve this error
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
Dec 11, 2009 | Canon imageRUNNER 210S Copier
The copier is giving an error message U6 what does this mean
It's a communication error between the base machine with the LCC ( Large Capacity Tray ) Try reset by following this step :
Press [#] [interupt] [c] [interupt] [1] [6] [start]
The copier will be reset and hopefully your error code too.
May 14, 2009 | Sharp AR-5320 Black and White Copier
I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Jan 10, 2009 | Toshiba E-STUDIO 650 Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
Error 000001-0004 ON MY IMAGE RUNNER 2620N,000001-0003 on3200n
ok that code has nothing to do with your drums that code is for a error in the fuser unit, you have to reset it in this order ADD FUNC key// then hold down the 2 & 8 keys at the same time / then ADD FUNC key again... screen should change to serv mode.... then in this order.touch copier/func/clear/err. ok turn off copier then back on... if code comes back you have a bad fuser unit swap it out clear the code again then try the new unit
Dec 22, 2008 | Canon Office Equipment & Supplies
What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Dec 16, 2008 | Sharp AR-207 Copier
52 people viewed this question
jasbo
jasbo
