Question about Pitco Frialator 35CD Deep Fryer
Are there any electrical connection to fryer
To ignite flame
    Top Expert:
  • 10,875 Answers
If it is gas,no,,if it wont light,then the thermocouple is bad
Posted on Apr 23, 2015
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Imperial 40 ignites but does not extend flames into heating tubes. Burns only fron
It sounds like your gas line either is clogged or your heating tubes are clogged up with oil/dirt/gunk? You can blow these out with a small hand held compressor or if you have a small enough brush, you can use that to clean it. The compressor is the quickest way, but have you cleaned this unit at all? Using a fryer boil out and running the fryer will also help clean out your holes, but again, the compressor works best.
Nov 21, 2011 | Imperial IFS40 Deep Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
Pilot lights but ignitor still igniting and burners will not light.
check if pilot flame reaches the ignitor tip, if it does, check the connection of or replace the ignitor cable.if it does not, adjust he ignitor so that pilot flame will have good contact with the ignitor.
Mar 07, 2011 | Pitco Frialator SG14 Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
Fryer comes on gets to temperature, then after a varied amount of time depending on use will power down, and will not come back on to maintain temperature, or will occasionally come on, but not to desired ...
Hi there.
Thermopile must be free of soot or any form of dirt so that it coud absorb the right intensity of heat from the pilot flame for millivolt generation used in energizing the pilot and main valve electrical coils for pilot and burner operation. Pilot flame must be stable during fryer operation as well as the gas pressure being supplied to the unit.
All wiring connection must be tight, a very small amount of voltage generated by the thermopile or millivolts will not pass thru loosely connected wires.
Regards.
Nov 04, 2010 | Pitco Frialator SG14 Deep Fryer
Burners are bleeding gas causing rollout flames
multiple problems can be causing this: 1.burner orfice restricted 2. make up air 3. blower motor or relay defective 4.gas pressure to high 5. not enough gas pressure 6. restriction in gas line 7. defective gas valve 8. defective control or ignition module........recommend qualified tech. to look at
May 23, 2009 | Pitco Frialator 35C Deep Fryer
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Imperial IFS50
Hi, Probably the thermocouple. It will be right at the pilot light and hooks to the gas valve. The pilot heats it up to tell the gas valve that the pilot is working. If this is an electronic ignition, It will be the flame sensor still close to the pilot and will need cleaned or replaced. Hope this helps.
kstfas
Jan 10, 2008 | Imperial IFS50 Deep Fryer
Only one side works
your control board is bad or one of the relays is bad.
Dec 17, 2007 | Frymaster Dean MJH50-SD Deep Fryer
Pitco Frialator 35CD Deep Fryer Logo
116 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
