Question about Better Toaster Ovens
What setting should i use to cook food in the oven,
It has lots of settings unsure which one cooks better
  • Sandra Gaspar
    Sandra Gaspar Apr 23, 2015
    Its a bigoven nottoasteroven
    Scholar:
  • 116 Answers
Press button C, then button A and finally button B. It works for ALL ovens and EVERY conceivable type of food you wish to cook which is handy considering you do not want to tell us what oven you have or what you want to cook in it.:-).
Posted on Apr 23, 2015
    Top Expert:
  • 10,875 Answers
Pick one and go,you see,we dont know what stove you are talking about or what settings because you failed to tell us these things in both questions
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): faberware-electric@saltonusa.com OR 1-888-881-8101. Ask for Operating Manual
Dec 29, 2014 | Farberware T490C 1500 Watts Toaster Oven...
What ever joint of meat i cook in the halagen oven it always ends up tough
You do not give much information so here is what I suggest not knowing what you have tried. Set it to a lower temperature and cook it for a longer time. Usually slower cooking makes things tender and still keeps them moist. Also, find a good marinating sauce or tenderizer to use before cooking.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 20, 2011 | KitchenAid Toaster Ovens
When i put food in on oven setting it burns at the temp it is supposed to be at
Possibly the oven is running at a higher temperature than what you set it for. This is not uncommon for ovens. Get an oven thermometer to check what it actually runs at and then you can adjust the temperature you set it at accordingly.
Feb 19, 2011 | Cuisinart TOB-50 Toaster Oven with...
I just bought this oven & my daughter lost the manual that goes with it. I need to know how to use the rotisserie feature. Also need to know if the rotisserie can be used for a roast. Thank you. =)
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast when I first got it and they were no better than pan roasted and a lot more trouble.
I have posted the complete manual (3 language edition) here:
http://216.92.50.93/Manual.pdf
Dec 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
No problem just need to know how to use the rosterrrie
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast on when I first got it and they were no better than pan roasted and a lot more trouble.
Dec 23, 2010 | Hamilton Beach 31197 120 Watts Toaster...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven does not cook at temperature set at. 2 hrs.
    Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
    Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Farberware Turbo Oven T4850- can't understand temp dial
    Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
    Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
    What is exactly a toaster oven?
    A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
    Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
    Toaster Ovens Logo
    276 people viewed this question
    Top Better Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Better Toaster Oven Expert? Answer questions, earn points and help others
