My esc on my slash 4x4 vxl-3 is blinking green rapidly an does not stay on when I let off the power button...the light blinks only green
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
  • 3 Answers
Even if you replace the capacitors already mentioned in this
thread, you may still suffer from the Green LED of Death. Here is how Bronson279 helped me resolve the
problem. But note that it involves
adding a switch to your tv set and requires a bit of soldering ability and the
willingness to void your warranty. BUT
you can save big $$$$ on sending the set out for repair.
Here is my solution-
After replacing several bad capacitors (you can get replacement capacitors
from Mouser electronics on line by the way.. be sure to order the same capacitance
values and same or higher voltage rating and be sure they are rated for 105
degrees C.) I still had the dreaded G.L.O.D. Note that the first time I plugged it in
after taking it apart the G.L.O.D was not there and it powered up
normally. But when I had to unplug the
set to fully re assemble it, it came back.
The issue is caused by both the FMT board (formatter) and
the DM (Digital Module) board’s microprocessors tying to establish
communications with each other. Somehow a race condition gets started with each
thinking that the other board needs to be reset and then starting the boot
process over again.
You need to interrupt this cycle with a switch. Buy a DPDT switch from radio shack (or Mouser
Elec…) and again take apart your electrical chassis (If you have it apart
replacing bad caps you might as well add the switch or you may end up having to
disassemble the whole thing again.) On
the FMT board along the top edge near the input connector side of the chassis
there is a four wire connector labeled “FC”.
It has two black wires and 1 orange and one Brown wire. Leave the black wires connected and cut the orange and brown ones about an
inch from the connector. Solder four 12
inch wires onto the ends (one on the source side brown, source side orange and
one on the connector side brown and connector side orange) use heat shrink tubing to cover the solder
connection points. (If you can’t get tubing, then electrical tape will do, but
make sure the joints can’t short out to each other or the electrical chassis.) Now take the brown and orange wires from the
connector side and solder those to the middle two terminals of the DPDT switch
(one on each side not both to both terminals) Then pick one side of the outside
terminals of the switch and solder the source side brown and orange wires to
the terminal across from the same color (brown across from brown and orange
across from orange) See the diagram below.
The idea is to connect the wires normally when the switch is closed and
break the connection when the switch is thrown the other way. Before soldering
the wires to the switch add a piece of heat shrink tubing to wire so that you
can cover the solder point up after it is assembled.
Now re-assemble the electrical chassis and route the switch/wires
outside the chassis (I snipped a hole along the edge of the top fan shield to
get the wires out.) and put it back in the TV.
You need to also get the switch to the outside of the TV somehow (I
drilled a ½ inch hole in the plastic cover to snake the switch through but you
can do it however you like)
Here is how to use it-
From a fresh plug in- throw the switch to the OPEN position (the wires
are not connected) plug in the TV, the green LED should stop blinking after 60
secs like it is supposed to. Once it stops, flip the switch the other way so
the wires are connecting. Hit the power
button. The TV should turn on- your done!
Yeah!
From a plugged in, hmmm my power must have gone out,
state. Assuming you have the GLOD, flip
the switch to the open position, hit the reset button on the front of the tv,
wait for the blinking to stop, flip the switch back closed and turn the TV on
normally… Again you are done…
Note that the first time you turn on the TV you may have to
flip the switch the other way (if the TV won’t turn on even without a blinking
LED) This means that the switch was open and you need to have it closed to get
it to work. If you tried turning on the
TV with the switch open, start over by following the reset button procedure
above.
Note this is much easier to do than it sounds. Also note that it helps if you have the
repair manual. Its titled V26 Repair
Manual –full This is nice to have
because it has a wiring interconnect diagram also which details all the
connector placements
Posted on Jan 11, 2009
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Posted on Mar 07, 2009
  • 10 Answers
SOURCE: I have had a Mitsubishi DLP 52525 for 6+ years now
I don't know about nettiser's credentials, but I've found plenty of people who would disagree with his/her assessment.
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Posted on Aug 03, 2010
My traxxas slash 4x4 vxl keeps making a clicking noise from the transmission
there may be a piece of debris got in there. I had many issues with my traxxas car, and sold it off to someone else. losi makes much better
Oct 21, 2013 | Traxxas Slash 4x4 VXL RTR w/2.4 TQi Amsoil...
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
Jul 07, 2012 | Traxxas Link 2.4 Ghz 5 Channel Receiver...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
I need the codes to program my Innovage Jumbo Universal Remote for Dynex television
As there are no specific codes for the Dynex TV you have the choice of either using the Auto or Learn method. The following are instructions for both:
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. *
Mar 02, 2010 | RCA RCU600M Remote Control
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
