Question about Steinberg Cubase 5 Full Version for PC, Mac
MPK49 keys are not responding in Cubase 5
I got the transport functions and all the knobs to work fine. The keys however are not working with cubase5. Everything is working great with Ableton Live 7 and Protools 7.4cs. When I press a key, I can see MIDI activity. And before you tell me turn MIDI thru on, Let me tell you it's on. I upgraded the firmware to 1.0.5. Loaded the preset files that I got from Akai Pro. Can't figure this out.
Polaroid FLM-373B not responding to any ir remote controls. Neither the OEM one or a Direct TV universal remote that has supposedly been 'programmed' for the TV.
Hi there
My first reaction is to disconnect the power supply for 5 minutes (often works wonders) With the power on again look for the function knobs on the TV itself. They are usually down in the right hand corner on the front. They have the same function as the knobs on the remote.
Give it a try.
Good luck
Kolbrun
Feb 20, 2012 | Televison & Video
I am having a problem getting sound out of a program called cubase 5
In cubase go to "Devices", there select "Device Setup", in the Device Setup windows go to "VST Audio System", on the top right you will see the "ASIO Driver" drop down menu, click it and select your sound card from the list. Also take a look into VST Connections.
Jan 10, 2012 | HP dc5000 PC Desktop
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to retrevo.com and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
The buttons on the top of my keyboard do not
check to see if the drivers to the keyboard are installed these keyboard options only work with it software installed!
Sep 08, 2009 | HP DC170B Keyboard
Proble opening saved project in Cubase SX3
Alot of people complain about the same problem with Vista... Vista is just full of problems... all it is is another ploy to send bulk cash to Bill ****** Gates
Jan 21, 2009 | Steinberg Cubase SX3
Function keys dont work
Go BIOS and check if the FN key be disabled.
Nov 11, 2008 | Toshiba Satellite 5005-S504 Notebook
Cubase 4 Error Message
Same problem with audioprimitive.opt on Cubase 4
Mar 21, 2008 | Audio Players & Recorders
Steinberg Cubase 5 Full Version for PC, Mac  Logo
275 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
