Question about Pitco 35CS Economy Fryer, 35 lb Capacity, Propane
How do i connect a gas fryer
The electrical side
    Top Expert:
  • Pitco Master
  • 45,340 Answers
You call an electrician of course
Posted on Apr 23, 2015
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
Are there any electrical connection to fryer
if it is gas,no,,if it wont light,then the thermocouple is bad
Apr 23, 2015 | Pitco Frialator 35CD Deep Fryer
How can you change electric fryer to propane
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
May 19, 2014 | Wells Kitchen Appliances - Others
Gas connection location on the back side. I am getting two 14's and two 18's. Location of the gas connection and it's size!
For the best gas installation/ instruction manual you can visit and download Owner's Manual at
http://www.pitco.com.
Regards.
Jun 23, 2011 | Pitco Frialator SG18S Deep Fryer
Pilot goes out when you turn up thermstat
The thermocouple, the part that is heated from pilot light and produce small electricity and is connected to the gas valve, is a small copper pipe wire, need to be replace since it can not enough electricity so to keep the electromagent on valve on when you try to turn up and the gas coming out from the burner is blowing out the pilot light.
So the most posible reason is to replace the thermocouple which is the cheapest part. Their is a very small chance that the gas valve is faulty but this depents how old the fryer is and how much have been work.
May 09, 2010 | Imperial IFS40 Deep Fryer
I have a gas fryer (pitco) that has no electric running to it,why does it have wires running from the thermocoupling
The thermopile on gas operated equipment acts as small voltage generator when heated that energizes the pilot valve and main valve of the gas valve,. Without it, you will not be able to fire up your fryer.
Apr 28, 2010 | Pitco Frialator SG14 Deep Fryer
550 degrees and shuting down
Replace the thermostat. If it's really getting to 550F without shutting off the pilot and main burner, or the electric in an electric fryer, by tripping the high limit, replace the high limit as well. The high limit should shut off all the gas or electric at about 425F.
Feb 25, 2010 | Pitco Frialator 35CS Deep Fryer
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
Fryer problem
The problem is with your cordset if it is a DP16, Here's how to fix it.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Oct 26, 2007 | GE 168952 Deep Fryer
Pitco 35CS Economy Fryer, 35 lb Capacity, Propane Logo
111 people viewed this question
Top Pitco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pitco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
