Question about Ovens
I have a problem with my indesit built in oven FIE 36 K.B GB, i switch on the oven, it heats up then the fan stops working.
Switch on oven, all going fine for about 7 mins, then the fan stops working. I leave the oven on for a few more minutes and the fan starts up again briefly and then cuts out again. we have recently replaced the thermostat and have replaced the oven bulb as that stopped working. The oven gets a lot of use, it is on for at least 1 1/2 hours on week days and about 3 on a saturday and sunday. Do you have any ideas which could help with this problem. Thank you.
  • 4102 Answers
SOURCE: AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Posted on Nov 05, 2007
BNewberry
  • 93 Answers
SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Posted on May 15, 2008
barkencoa
  • 3463 Answers
SOURCE: neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: my indesit electric oven cuts out after about
It is probably the overheat safety thermostat that is operating due to oven overheating.
Check to see if the top cooling fan is working, and if it is built in, make sure it has adequate ventilation.
Please rate my advice.
Thankyou.
Posted on Jun 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Indesit FIE 56 K.B GB oven The circulation fan is squeeking
The symptons you describe are typical of the fan motor bearings failing. you could try spraying the bearings with WD40, but this would only be a temporary solution, in the end you will probably have to replace the fan motor complete.
Hope this helps.
Posted on Jan 07, 2010
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Regards
John
Nov 02, 2014 | Ovens
I have an Indesit oven FI 31 KB. It is 3 years old but never used as it is in a house I have just renovated. I turned the oven on, but the fan did not come on as it is expected to do. Oven and light seem...
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
Oct 19, 2013 | Belling XOU492 Electric Double Oven
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I have an Indesit oven model FIE 36 K.B GB, I need to replace the bulb but I'm struggling to get the glass lamp protector off. I've looked in the manual and it says it should just twist off but all...
A common problem with some oven manufacturers I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it. However, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Sep 06, 2011 | Ovens
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Hope this helps.
Jan 07, 2010 | KitchenAid KEBC101 Electric Single Oven
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
My indesit electric oven cuts out after about twenty minutes, will not switch on again until it cools. is this caused by a faulty thermostat?
Thankyou.
Jun 04, 2009 | Ovens
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
