Question about Samsung 4.5 Cu Ft Capacity White Top Load Washer With Aquajet - WA45H7200AW/A2
Why is there lint deposits on clothes after every wash?
    New Friend:
  • 41 Answers
It's normal. Just a little wear on clothes. Be careful with this model though, the pump is mounted to the bottom of the drum. Its supported by a plastic cage and it fails within 2-3 years causing the pump to fall off, subsequently flooding the area. Tilt the washer and look at the pump assembly. If the cage is cracking call Samsung now. Ask them to pay for parts & labor.
Posted on Jun 10, 2015
Lint clothes washing
this grease from the bearings
the problem is more likely to be the bearings
does it sound loud in spin
Jan 31, 2014 | Bosch Washing Machines
My LG Fuzzy Logic WF T653A machine deposits little black unknown deposits on my clothes after every 2nd or 3rd wash, they look like little bits of black wet paper ?? some-one said to change the lint bags,...
Its called scrud.
Solution is to use a couple of quantum dishwasher tablets on a hot empty heavy wash.
Doing this on advice from an LG rep. May need to repeat it 3 times.
Brendan
Mar 24, 2013 | Washing Machines
Clothes are not drying yet they are hot. Wondering what could be wrong. Model #11072812100
Vacuum out all air vent spaces and hoses including the outside grill. Wash the lint filter in hot water and detergent to remove the fabric softener deposits which block air flow. Hope this helps!
Jul 28, 2010 | Kenmore Dryers
Problem for Frigidaire FSE748GF Dryer Brown marks on clothes - What could the problem be and how do you fix it.
If the clothes have a 'burned' smell, likely, the air flow through the machine is restricted and getting too hot. Vacuum out the exhaust hose and the outside vent of lint. Reach inside the machine's air outlet pipe and vacuum all that you can reach. Remove the lint filter and wash it in hot water and detergent to remove fabric softener deposits. Vacuum below the lint filter opening as far as you can reach and inside the door cavity (be careful of sharp edges!). Hope this helps!
May 16, 2010 | Frigidaire FSE748GF Dryer
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
My whirlpool duet dryer doesn't get my clothes completely dry. We have replaced the sensor and checked all the ducts. I still have the same problem. Any other suggestions?
Try washing the lint filter in hot water and detergent to remove fabric softener deposits that block air flow. Hope this helps!
Jan 18, 2010 | Dryers
Dryer will not dry clothes in single cycle, and towels smell burnt why?
Check the entire air vent system for lint obstruction. Remove the lint filter and wash in hot water and detergent--fabric softener sheets will build deposits on this screen, which restricts air flow.
Sep 07, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore top loading washer -- deposits lint or fine dust on the clothes so that they come out dirtier than when they went in.
Remove the hoses from the pump and inspect the lint trap (inlet strainer) for build-up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2009 | Kenmore Washing Machines
Lint in washer somewhere
It probably isn't the agitator. Are you sure that it is lint and not the clothes getting torn up? One thing you might want to try is this. First take and pull the basket to one side and clean the gasket on top of the basket. There may be gunk built up on it that is transferring to your clothes. After you do that, just like a coffee maker, put about a cup of white vinegar into the washer and run a wash on hot water. After the load wash again without the vinegar just to make sure it all gets out. This is a good way to keep the washer clean all the time too, do this maybe every 3 months or so. I will clean any hard water deposits built up on the hoses and such and you will notice you clothes coming out cleaner. You can do this with your dishwasher too. Let me know if you have any other questions and if this was helpful to you at all. Good luck and I am glad that I could help you out.
Jan 16, 2009 | Kenmore 24032\24036 Top Load Washer
Deposits on clothing
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Samsung 4.5 Cu Ft Capacity White Top Load Washer With Aquajet - WA45H7200AW/A2 Logo
87 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
