Onboard realtek sound problem no sound just garble popping and static through speakers
Onboard realtek sound need drivers to make work HD Audio audio
  • 3,320 Answers
Try reinstalling the drivers. http://www.realtek.com.tw/downloads
Posted on Apr 24, 2015
chiplevel
  • 656 Answers
SOURCE: ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Posted on Nov 30, 2007
eng_ebrahim
  • 9 Answers
SOURCE: asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Posted on Jan 03, 2009
ChipcircuiT
  • 157 Answers
SOURCE: install failure for audio driver realtek HD 51.81
maybe you have some driver conflict from version or maybe some hardware issue..you must check this both.
Posted on Jan 08, 2009
the_fire
  • 432 Answers
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Posted on Apr 14, 2009
blubaustin
  • 242 Answers
SOURCE: Realtek HD Audio Driver Installation
It has a autodetection for when jacks are plugged into the audio port. Maybe the connection isn't just perfect, or there is corrosion/debree on it causing it not to make perfect contact. If that isn't it it may be the wrong driver.
Posted on Jul 28, 2009
Realtek audio not install
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.
hope this helps
Jun 18, 2011 | Computers & Internet
Have installed video codecs still no sounds
Hello there!
You need to install sound drivers in order to make your pc play sounds, and you also need to plug your speakers on to pc output (green hole). I suggest you trying of Realtek hd audio drivers , they should be working for your onboard sound card.
Sincerely
Aleksandar Adzic
Apr 17, 2010 | Microsoft Windows XP Professional
The ECS A770M-A onboard REALtek audio problem
if everything is up to date, softwares, and other related issues you had mentioned...seems like the audio amplifier in your pc is not functioning or it had been damamged...alc880 high definition audio driver, try to uininstall it, and if you had tried any other related alc drivers to install..remove it from the system and re-install it..if it works..no problem, if it dosnt..try to play your media player, if you are able to see graphics moving...then your audio amp is damaged..check out
Oct 14, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Asus M2V Audio problem
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Can hear sounds but no voices and Music garbled
I had this same problem and resolved it by unchecking the "karaoke" icon on my RealTek HD Audio Manager that I guess I accidentally checked the night before. To make sure that you don't have the karaoke turned on, double-click on the RealTek HD Audio Manager icon locationg in the bottom right corner. There is a karaoke icon on the top right of the window that pops up - make sure there is no "X" on the icon. If there is, click on the icon to get rid of it.
That did the trick for me, hope this helps.
Cheers
Jan 12, 2009 | Zoltrix Zling U2 MP3 Player
Jan 02, 2009 | ASUS M2V Motherboard
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
Failure of realtek audio driver installation
I had the same problem while installing a GeForce 7050M-M motherboard w/AMD quad core processor. I kept getting the message "install Realtek HD Audio driver failure!!" message. After many hours of futility, and reading possible solutions on the internet, I got it working this way: First, go into your cmos setup and disable your onboard audio. Then after you boot up, go into 'control panel' and then 'add/remove programs' and remove any program associated with high definition audio. The Realtek programs that I had tried to install were in mine, so I deleted them. Then I clicked on 'start' and then 'search', and put this in the search window: 'hdaud' for high definition audio. Several files came up, and I deleted them, which put them all in the recycling bin. I didn't empty the bin, in case I screwed up something and had to restore the files later. I then rebooted, and being probably overcautious, let the computer come up and then went back into 'add/delete programs' to make sure there were no HD audio programs in there, and then double checked for any files by going back into 'search' and searching for 'hdaud' files like before. A file somehow had appeared there associated with Realtek, so I deleted it. Then I rebooted, and at reboot went into cmos setup and enabled my onboard audio. When the computer came up, the 'found new hardware' message popped up. When you see this DO NOT let the computer look for the driver. Hit 'cancel', and load your Realtek audio drivers from your setup disc or from whatever location you have them in. You may see the additional message about the driver not loading and your sound not working right, but ignore it, it's because you clicked on 'cancel'. Just let it finish it's install from your setup disc. When mine finished successfully for the first time now, and it prompted me to reboot because of the new drivers just installed, I actually got the 'shutdown' sound out my speakers-the first peep I heard out of them since I started this adventure early yesterday. When the computer came up, lo and behold I had sound. I was about ready to give up and go out and buy a sound card, but stubborness prevailed. So in short review:
1. Disable your onboard audio in CMOS
2. Go into 'add/remove programs' and delete any and all HD audio programs
3. Go into 'search' and type in 'hdaud' and delete those files that come up.
4. Reboot and double check 2 and 3 above.
5. Reboot and go into CMOS and enable your onboard audio.
6. Load your audio drivers from your setup disc-DO NOT LET THE COMPUTER LOOK FOR A DRIVER THRU THE 'FOUND NEW HARDWARE' PROMPT-PRESS CANCEL.
7. Reboot and hopefully, enjoy the sound.
Oct 07, 2008 | Microsoft Windows XP Professional With...
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
