My screen isnt showing on my laptop, what are my options
The screen is out like a picture tube goes out on a tv
    Top Expert:
  • 10,875 Answers
Get a new one,get a new one
Posted on Apr 23, 2015
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture problem
If all your wanted is to widen the picture then just push aspect or format on your remote control and put it on either 16:9 or full. But if your referring to HD then an HD picture fills the screen by itself no matter what setting you have the tv set to. If the screen isnt full then the program your watching isnt broadcasting in HD at that time. A common misconception is that because its an HD tv or an HD channel that it always should show in HD. This isnt true. It goes by the broadcast
Apr 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
My tv is showing to much red on screen
I don't have a lot to go on. If this is an older rear projection, this usually means the face of the green picture tube is dark (the picture goes purple-red) or there is too much red tube(excessive drive). This is a technical adjustment as it is in an area containing hazardous voltages. Adjustments will be a stop gap as rear projection TVs are all past their usable life span (About 8 years + with moderate use)
Mar 21, 2010 | Philips Televison & Video
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
How to connect vista laptop to tube tv
If your laptop has a s-video output you can get a s-video cable that goes from your laptop to your tv's AV input.
You then just have to activate the alternative display on your laptop to make it work if it doesn't detect it automatically. Hope this helps.
Cheers
Sep 30, 2009 | Televison & Video
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
MY problem with Sony KP-53S35 53 in. Rear Projection Television. When the TV powers on, the red light blinks until the picture comes on, then the red light blinks go off. I had to wait more than 5 minutes...
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Jul 27, 2009 | Sony KP-53S35 53" Rear Projection...
Screen save stops displaying
If you go to Start Menu --> Control Panel --> Power Options --> then look the option that allows you to change the amount of time that the system turns off the monitor because of inactivity.
Apr 15, 2009 | Toshiba Satellite A215-S7422 Notebook
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
