I set for tub clean.after 30 minutes the water has filled in the tub and it stop running. When i try to reset the lock is automatically getting locked,unlocked.the C9 shows on the panel.help.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Inter lock?????
Posted on Apr 27, 2015
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
Washer
1) please the timer for defective, however clean the contacts very well, loose wires, or broken and repair.
see the diagram attached
2)no cold water, see this and fix it.
God bless you
Jul 02, 2012 | Washing Machines
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
Water does not come out ...is there a fix
mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Jul 09, 2010 | Mr. Coffee TFTX85 Coffee Maker
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Jun 04, 2010 | LG WM2277H Front Load Washer
Timer not working does not stop automatically
Hello, This is going to be a problem with either the moisture sensor which is the metal strips inside the back rear of the tub or the running thermostat which is normally located on the exhaust vent right near the blower. Try cleaning the moisture sensor first. To test this problem set the dryer for a timed dry for 30 minutes. If the dryer stops the above is your problem. If you have any other questions please feel free to comment again. Good Luck!! Mike
Oct 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MAV5000 washer, water filling does not stop, small tube in back is hooked up.
Remove the small tube from the water level switch and blow through it to clear any clog in the air dome on the side of the tub.
Remove the small tube from the air dome and blow through it into the water level switch to reset it.
Then set the machine for spin and run spin cycle for 1 minute. Then try your fill again. If it does not work this time, replace the water level switch.
May 21, 2009 | Maytag Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
Apr 05, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
