Question about Garden
When the PTO is engaged a loud thumping noise is heard and felt. It feels like it is right under the seat. If feels more like a Jolt.
    Sergeant:
  • 462 Answers
Sounds like universal is bad or bearing
Posted on Apr 23, 2015
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
How can i get pto cluch to ingage?
This problem needs more information provided.
Look for safety interlocks that have not been engaged, or possibly broken. The switch under the seat will not allow the PTO to engage if it does not detect someone in the seat.
If the PTO is electric, look to see if the plug is loose at the PTO.
Check to make sure that the PTO mounting bolts are still secure.
May 20, 2014 | John Deere Garden
Runs but wont go into gear. Just grinds after feeling a thump.
if the bike only grabs gears with the rpm way up there is a chance the clutch is gone or just about. make sure the clutch is properly adjusted. Also if it is a wet clutch be sure you have the proper amount of the right oil. if there is super old oil in the clutch plates they wont grab.
Apr 10, 2014 | 2002 Yamaha Xvs650 Xvs 650 Xvs650a V Star...
Everride warrior pto wont engage
most likely the engagment switch, usually yellow knob. the seat safety shuts the mower off so if the mower is still running it is not the safety under the seat.
May 05, 2013 | Garden
I have a white outdoors riding mower....the mower shut off when i engage the pto...is the switch bad?.....can i by-pass it?....how do i test the switch????
Check the safety pressure switch under your seat. When you engage the PTO and get off the lawn mower, it will kill the engine. I had the same problem; drove me nuts. I thought it was the switch that is compressed when the PTO is engages. It wasn't. It was the safety under the seat. Bypassed and it worked fine. Ordered a new switch from a local repair shop. Good luck.
May 26, 2010 | Garden
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Tranny failed '96 Grand Cherokee Orvis Edition
I just had to replace the gov solenoid and sensor in trans.Would do same thing ,feel like someone shifted to neutral.
Jul 19, 2008 | 1996 Jeep Grand Cherokee
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
