Question about Lands Phones
How do I get on to the housing register - Lands Phones
How do you change number plate housing for lexus is250 2008
Changing vin by self is illegal if thats what your doing
If its door plates or firewall plates dealer has to order new and you have to take down to mvd and register numbers
If license plate unscrew it
But overall changing any of the cars factory registered plates is illegal without registering them threw proper channels first
Mar 22, 2015 | 2008 Lexus IS 250
What size furnace do I need to replace my old lenex model number g20qq3 4G 125 4
If we're talking physical size, modern units won't be the same, you could essentially look at any manufacturer's dimensions and see what gets closest. For BTU's it's better to base it on the size of your duct system. Generally, or just unprofessionally, lets say 8,000 btu per register. If you have 10 registers in the house, an 80kbtu unit would do nicely. 16 registers - 120kbtu. They max out around 150kbtu. However, I highly recommend you have a professional do it all. If you do something wrong, you could very easily kill yourself or anyone in the house. The risks are huge; installations should be done by licensed contractors under a permit. Plus, contractors should know all of the new energy saving tricks, they could save you tons by changing your system altogether.
Apr 10, 2014 | Heating & Cooling
How register a vtech house phone
my dear,
the model number you sent is not valid, check very well and send me a correct model number to enable me get you a user manual
THANK YOU FOR CHOOSING FIXYA
Nov 25, 2011 | Vtech 9009111 Cordless Phone
When range burners set to low they go out when house furnace fan turns on?
This is a common problem when the furnace register is located in or near the kitchen. You will need to close the register(located in the ceiling) or adjust it so the air is not blowing toward the range burners. They also make deflectors that you can install on the register to direct the air away from the range.
Dec 18, 2009 | Kenmore Kitchen Ranges
I would like to now were the thermostat is on an 1990 mr2
Follow the upper radiator hose to the engine block. Where it attaches is the thermostat housing. Under the housing is the thermostat. The housing should have 3 bolts on it.
You can go to autozone.com and register for full free online repair manual.
Nov 24, 2009 | 1991 Toyota MR2
I have the cash register Casio PCR265P
Hi. Standard problem with this kind of printer. The rotary switch gets dirty. If you want to try fixing it yourself, unplug the machine, remove the screw inside the printer compartment that holds the machine to the drawer. Slide the whole top section forward on the drawer, then lift upwards to remove the cash register from the drawer. Gently turn it over so you can see the bottom side of the printer. On the printer, you will see a black plastic housing at one end with little wires going into it. This is the switch housing. Get a can of general purpose luricant (such as WD40) and spray into the black housing. Try to get the spray into any little gap in the housing, or under a corner. I don't recommend unclipping the housing as it can be difficult to reassemble. Just get the spray generally inside it as much as you can. Don't be afraid to get the spray on other areas, it won't harm it. Your paper might be wet for a few prints that's all.
Once you have sprayed it, plug the machine in and try it. Sometmes it takes a few sprays and on off cycles before it works, but it will usually do the trick if there is nothing else jamming the printer.
Mark
Dec 28, 2008 | Casio Parts Cash Register PC Desktop
House phone problem
Please be sure to put the extra handset in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Best Regards!
Brian
Oct 29, 2008 | GE 25952 Cordless Phone
PHONE WAS DROPPED INTO POND
dropped house phone in toilet? help
Jul 03, 2008 | Lands Phones
Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Brian
Jun 15, 2008 | GE 25942GE2 Cordless Phone System
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
