Question about Zanussi Washing Machines
What's your question?I have a zanussi ZWH3125 washing machine after filling water the spinning is not normal its too fast its as if it want to rinse
    Genius:
  • Zanussi Master
  • 1,585 Answers
Mcb
Posted on Apr 30, 2015
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
SOURCE: My Zanussi ZWF 1221 W will not rinse. Any ideas?
my zanuzzi 1500 will not rinse
Posted on Aug 22, 2009
miket756
  • 2702 Answers
SOURCE: My Hotpoint WF860 will spin on rinse/spin load but not on a wash
no its the programer at fult
Posted on Oct 25, 2009
  • 714 Answers
SOURCE: water not leaving machine
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 17, 2010
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool washing machine won't rinse nor spin. I changed the lid switch but still won't work
The spin function is normally controlled by water level control switch not allowing operation until all water is pumped out,rinse should activate water valve to add clean water,if machine fills ok initially the problem seems to be in the controller not activating certain parts of the normal cycle.
Apr 30, 2011 | Washing Machines
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Just want to know how to get the fasted wash as it seems to take about 1.5 hrs to do a load. zanussi xc6 1400
Check your screens on the fill valves. This is a good time to replace the fill hoses, the last thing you need is an old one to blow. Wash warm, rinse warm, both fill valves will be open. If you only use cold water, hook both fill valves to cold water, cold water will go thru the hot fill valve for a faster fill.
Aug 18, 2008 | Washing Machines
Zanussi zwf1211w
are the water supply taps fully on ? check that it is filling quick enough. let my know how you get on. also is it heating the water?
Feb 16, 2008 | Zanussi ZWF1430W Front Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
