Require Filter Kit - Computers & Internet
    Genius:
  • 1,552 Answers
Your ISP should have provided you with a Filter Kit.
Put one filter on each telephone-outlet that is *NOT* connected to their DSL-modem.
Posted on May 11, 2015
Press primer bulb will start. I attempt to throttle but dies out what probable cause of this
HI
I assume you have the choke/throttle setting on.
Sounds like fuel shortage.
Check tank filter.
I assume fuel is good in tank (not old or contaminated).
Get someone to give about half throttle will you attempt to start it, to see of this helps.
Otherwise you may require a new carburettor kit which includes a fuel pump replacement.
Regards
Jacko from downunder
Apr 24, 2014 | Stihl Blower Air Filter Br 500 550 600...
Stihl ms 290 wont start
Try replacing the spark plug and fuel filter to start with. Need to ensure you have fuel and spark. We have a list of things to check as techs but if it has spark fuel and compression it should run albeit poorly. If no spark check the ground circuit and if thats good replace the ignition module. If you have spark check the carburetor. It will most likely require a kit and cleaning
Jan 16, 2013 | Stihl Ms290 Ms310 Ms390 Air Filter &...
1998 Pontiac Sunfire. The Fuel Filter needs to be changed.It looks to be the original one, the fuel filter quick release clip is broken.The line will not come loose.What do I do?
if the black circular connector is what has broken,theres not much you can do but replace the
f/line.if its only parcially broke you can try pushing line towards filter,lightly squeesing,then
pulling apart.you may find a repair kit for splicing in a end connector.i seen this happen before
& most require a new line
good luck
Jun 22, 2011 | 1998 Pontiac Sunfire
Diffrent types of wring
Some receivers require a docking kit, mostly newer ones. Starmate 1, and Starmate 2 receivers just use standard ports and do not require a docking kit.
Dec 23, 2010 | Audio Players & Recorders
What is the maintenance protocol on a 2007 Dodge Ram 3500? Does it require some special, expensive filter and fluid?
this requires any transmission fluid meeting the standard of ATF+4, it is about $3 per quart, the filter comes as a kit and is about $15 (USD), very average cost for late models, no matter the manufacturer
Sep 02, 2010 | 2007 Dodge Ram Truck
My te 400 cxl weedeater starts but won't continue to run. can I replace the fuel or air line?
People replace fuel lines all the time as they deteriorate over time. This is a fuel delivery problem most likely and will require installing some new parts in the carburetor to fix. You can go with the cheaper diaghram kit or a full rebuild kit (includes the parts in the diaghram kit). This is a very, very common problem with these machines. If you feel you have to clean the carb at any time, only use non-flammable brake cleaner spray on it. Stronger cleaners and carb sprays can damage very sensitive internal parts. Don't use any high PSI air on it either as this has the same result as the strong cleaners. As far as an air line goes, these machines probably don't have one but they do have an air filter that needs to be checked or cleaned or replaced. They also have a fuel filter that is located on the end of the fuel supply line inside the fuel tank. Check that also.
Aug 14, 2010 | Garden
What size filter do I need for a Nikon D40 and what size filter do need for aSigma 70-300mm Thank you
Hi!
Usually the diameter is written on the front of the lens. You can use lens with different diameters on this camera, it really depends on the lens, but it will most likely be a 58mm.
Tom
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Just need info about changing transmission oil in 1996 Ford Crown Victoria LX. I'm not familiar with type of Transmission oil to use and how many quarts it holds and location of the drain plug.
You will need to drop the trans pan to drain. In turn you will need a trans filter kit which will include the filter and gasket. As far as fluid, it will require mercon dexron auto trans fluid, and will take about 6 quarts. What I normally do is fill with 5 qts and check, then add half qt at a time till full, which is normally 6 qts.
Oct 08, 2009 | 1996 Ford Crown Victoria
Oil in my air filter
Oil in the air filter could mean tht the piston rings are weak thus throwing oil from the breather to the airfilter via the breather pipe.
Some filters do require a little oil like thK & N ones maybe in your bike it was over filled if at all.
You can run the engine with out the air fliter and see if theres smoke coming out of the breather pipe, if it does thn you will have to replace the piston rings or more over rebore the block and replace the piston kit.
Hope this helps !
Knight.YamahaSeca XJ750A 1981)
Mar 03, 2009 | 1974 Yamaha DT 360
Ventillation of microwave
You mean NNS254? You can download your owner's manual here.
On page 4, it says, "If this appliance is to be vented inside the kitchen, be sure the charcoal filter kit is installed in the unit before you operate."
Also, on page 28, "The Charcoal Filter cannot be cleaned and should be replaced periodically every 6 to 12 months, or more often if necessary."
So the answer is "yes".
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Panasonic NN-S254BF Microwave Oven
Computers & Internet Logo
431 people viewed this question
David Payne
David Payne
