Question about Microwave Ovens
How i can use it step by step please - Microwave Ovens
    Problem Solver:
  • 41 Answers
More info about your microwave will help someone to answer to your question as there are different make/model of microwaves
Posted on Apr 23, 2015
Have frigidaire microwave and. Every time I try to set the clock it goes back to zero's # lfmv164qfa
That model does not apprear to be a valid Frigidaire US model number.
Did you try unplugging for about 5 minutes, then plugging it back in and trying it again?
It would also be helpful if you could describe in step by step detail what happens.
If you need further help, please verify the full model number from the tag / label and contact me via here.
Oct 12, 2016 | Frigidaire Microwave Ovens
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
The probem is ....the microwaveoven is not heat (kitchenaidKHMS2056SSS). Live of microwave.....4 months.\\ Could you please tell me if we can fix this problem.....we lost the manual of this...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 26, 2010 | KitchenAid Microwave Ovens
I need instructions for the replacement of glass cooktop. I have the spare part with me
The following link explains step-by-step how to replace a glass cooktop on MOST ranges:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have questions about any of these procedures, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | Microwave Ovens
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Doesnt work
Please see the following site for loads of troubleshooting steps for your microwave:
http://www.repairclinic.com/0088_6_1.asp
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can.
P.S. - You can rate asolution with one of four ratings as explained under (remember that at times abit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Oct 04, 2008 | Microwave Ovens
Microwave oven carousel won't turn
This may be a bad carousel motor problem. If it is, this is an easy problem to fix and rather inexpensive. Please provide me with the make and model number of the your microwave and I will attempt to locate a part number and price for you. I can also provide you will step by step instructions on how to repair. I hope this encouraging for you. Please post back with your information.
Jan 17, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
