Question about Honda Garden
Honda cg160 tiller the engine was running rough With choke all the way in, fine at halfway. then stopped moving forward,moves but no strength to till. What's wrong??
    Master:
  • 456 Answers
While your choke is out your engine is getting too much petrol . if it wont run well with choke in then its not getting enough. there is a small screw on the side of the carb ( air mixture ) they are usualy ( from screwed right in ) 1 and a half turns out, try with 1 and a half turns out start engine and adust either way so it idles nice ( try and warm engine up first ) also if you can't get it to idle you might have to strip card off and clean it ...hope this helps
Posted on Apr 23, 2015
4 Suggested Answers
jj505
  • 195 Answers
SOURCE: Tiller will start but will not move forward or back
Please check your drive is engaged and also check drive belt and gears. The drive assembly is what your looking for with this problem.
Please rate. Thanks jj505
Posted on Mar 28, 2009
  • 8 Answers
SOURCE: Rough Running
It depends on the type of engine but it sounds like your carbeurator is running lean. there is and mixture adjustment screw on most of the older models, alot of the newer carbs. are pre set to emission standards. try a fuel additive called sea foam, this product has solved solved many of my fuel related issues.
Posted on Nov 16, 2008
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
Why won't my rotor tiller stay running after starting Its a briggs and stratton
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Jul 08, 2014 | Husqvarna McCulloch Garden Tiller, 5hp...
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
I can not start the engine of small garden implement
if it has a brownish primer bulb on carb, pump it a few times, when cold the choke should be closed"full on". pull rope a few times with throttle depessed till engine pops, then move choke to half position still holding throttle, if all is well it will start and run, after about 10-15 second of warmup, move choke to open"off", if it won't start, i'll first ask has it been stored with fuel in it,the fuel may be stale or carb may need cleaning. pull air filter and try a shot of starting fluid, if it kicks over, you have a fuel delivery problem, if it won't fire on starting fluid, try replacing spark plug, if it still wont run e-mail me and i'll try to help diagnose ignition problem
thisoldtruck2@yahoo.com
Mar 16, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Mar 28, 2009 | Garden
Rough Running
Nov 14, 2008 | Garden
Garden Logo
145 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
