Question about Cell Phones
How do I get a code or password to make my Phone(U939) a wi-fi hotspot.
fidosolves
  • 31 Answers
SOURCE: wi-fi on e50
E50 doesnt have wifi feature i.e there is no hardware to access wifi,so u cant install wifi settings,if u need wifi,change the handset E60 has wifi
Posted on Oct 10, 2008
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
johnarcher
SOURCE: LG Renoir wi-fi connection failure
When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
John
Posted on Jul 03, 2010
SOURCE: The Wi-Fi on my HTC Wildfire isnt working. I tried
i dont know how to set my wifi
i encountered with some option named vpn
virtual private network
help me to make connection by wifi step by step in settings menu please
Posted on Jan 19, 2011
  • 50 Answers
SOURCE: My phone detects wi-fi hotspot
There are some wi-fi with encryptions that mobile phone cannot connect to
Posted on May 23, 2011
How can I use my hotspot for the HTC one m8. Originally it was a Verizon phone but I now use straight talk. Everything this far is all legal no hacks
      The password is the key other people need to enter on their device so they can connect and use HTC One (M8) as a wireless router. To helpmake your Wi-Fi hotspot more secure, tap > Advanced. Choose from the available settings, and then press . Tap the Portable Wi-Fi HotspotOn/Off switch to turn it on.
      Using HTC One (M8) as a Wi-Fi hotspot - HTC.com
      www.htc.com/us/support/htc-one-m8/howto/465106.html HTC
    Feedback
    HTC
Jan 23, 2016 | HTC Cell Phones
Tip
Set Up as a Wi-Fi Hotspot for the CAT (Catapillar) B15 IP67 Rugged Android...
From the home screen, you will tap the Menu key.
Next tap System settings.
Tap More.
Tap Tethering & portable hotspot.
Tap to check or uncheck Portable Wi-Fi hotspot.
In order to change the password or network name tap Set up Wi-Fi hotspot.
The Network SSID, Security type and Password will be displayed and may be edited as needed.
Finally tap Save.
Your Wi-Fi hotspot is now set up and ready to use.
on Dec 26, 2014 | Cell Phones
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 | Cell Phones
3. Select Settings.
10. Select a security protocol. Options are Open and WPA2 PSK.
-regards and update me
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
WHAT SOFTWARE WILL I NEED TO HTC WILDFIRE A3333 TO MY PC FOR INTERNET?
1. Touch Menu.
2. Touch Settings.
3. Touch Wireless & networks.
4. Touch Portable Wi-Fi hotspot settings.
5. Delete the existing text and enter a name for your hotspot.
6. Scroll down to Password.
7. Delete the existing text and enter a password for your hotspot.
8. Touch Back.
9. Touch Portable Wi-Fi Hotspot.
10. Touch OK.
11. The portable Wi-Fi hotspot is now active. Other devices can now connect with the Wildfire.
Apr 24, 2014 | liion 4400mah Li-ion Battery For Mecer...
Won'connecct to online sites
You don't mention if you have a 3G tablet, or do you rely on a wi-Fi hotspot on your computer or phone to connect your tablet?
On your tablet, go to settings,on left column, make sure WI-Fi is on, if not, touch it to enable. Your connection should show up on the right side of screen. press and hold the name of your wi-fi network, it will ask you "forget network" or "modify network" Choose modify network and make sure you type your wi-fi password in( do it again if it is already showing up.) I find it easier to use the feature for displaying what you are typing in. Hope this helps. You can also piggy back on a wi-fi hotspot on your smartphone.
Sep 09, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Receiving pictuer messages
I have had this same problem with Straight Talk before.
First, I would call them up because it would appears that sometimes, Straight Talk does not turn on the internet/picture messaging when doing the activations and they go amiss.
If you have wi-fi in your home or, if you are in a wi-fi hotspot, I would try sending a picture when you are own your own wi-fi or in a wi-fi hotspot. To do this, make sure your "Wi-fi" is turned "On" in the settings menu on your phone.
By having the "Wif-fi" turned to the on position, you can also save on your data usage by using your own wi-fi and various hotspots so you are not eating up your own data. I'm always surprised at how many people do not know this.
So check to see that "Wi-fi" is turned on in your settings and, send a picture over your wi-fi or a hotspot wi-fi. If you are able to send a picture over your wi-fi or hotspot wi-fi then you know that it's a problem with their network and at that point, I would cal Straight Talk and tell them that you are unable to send or receive pictures.
Jan 30, 2013 | straighttalk.com
How do you get onto the nintendo dsi shop!
To connect your Nintendo DSi to the Internet, your system will need to be in a Wi-Fi capable hotspot. If you have broadband at home, you'll need to set up a wireless router with a network name and a password. If the public hotspot requires users to enter login information via a webpage, this generally means that it will not work for DSi online play.
In the Settings menu, you'll need to select one of the first three profiles and search for your compatible Wi-Fi hotspot. Once selected, you'll need to enter the password of that hotspot. After a short test to see if the connection will work, as long as the information you've provided is correct your system will connect online. If you receive an error code, please note the digits and check Nintendo's Wi-Fi technical support website at www.nintendowifi.com.
Feb 20, 2011 | Nintendo DSi Blue Console
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
